Popper roasting question
Re: Popper roasting question
Ill let you know in a couple of days.
Originally posted by 6A7178697C6A71707F6D7C6B190 link=1320518555/16#16 date=1323575589I tried it once, well not purposely, I thought they were done enough dumped them, looked and went umm nope not done, put back in and tried for more, didnt happen and the beans ended up in the bin
Interesting, I have experienced the opposite.......
http://www.bestcafes.com.au/forum/home-roasting-all-about-the-culture/infrared-temperature-gun-for-roasting/
No because the aim is for a continual rise in temp; no stalling or decreasing.Originally posted by 775249495F5641330 link=1320518555/14#14 date=1323474801Has anyone tried dumping after 1st crack, holding beans in the collander for 1 or 2 minutes without trying to cool them, then reintroducing the beans to the popper to continue to 2nd crack, then final dump and cool?
If your popper is still running too hot you could do with a lot more holes.
Those few in the pic are not doing much.
Aim is to extend the period where the beans are very hot after 1st and before 2nd.
My popper is a hot one, sometimes reaching 2nd crack before 4 minutes.
It has 4 extra 8mm holes in the base and 10 x 8mm holes around the body- top and bottom.
Not enough holes.
I aim for about 10 min to first crack.
Have you added more holes underneath?
If you look closely youll see that half the vents underneath are not open.
Careful though as there is wirung under there.
Take the bottom off as best you can (one screw may go through the pcb) and then drill holes in the bottom.
You need to get more cool air in (help it breathe).
After that you can experiment with adding more holes to let the excess overheated (for what you need) air escape.
Hello All
Here is my (slightly) modified popper, I have found that the few holes in it are able to let out enough heat to slow the roasting process down a little, especially if there is a fan blowing under it. Shapeshifter, I guess your experience should serve as a bit of a warning for me, Im sure the minister for finance would be quite unimpressed if I were to ruin a $100 temp gun withing days of getting it!
I have the stick thermocouple sticking into the side of mine, sits about half way down the beans when they are in there and sticks out about half the radius, I use approx 80 - 100 grams each time, 100 grams when I measure them
I find it is very consistent.
I tried the gun but melted it trying to get consistent readings LOL
A picture would be nice people (if you can) as that makes feedback so much easier.
How many scoops are you doing each time crazy cat? Do you happen to have a picture of where you drilled. Im still tossing up if I should drill the actual popcorn maker itself. Having taken the thing apart I dont think this is a very safe option.
I did the angle trick as well but had a few issues with beans falling out of the chute corner. I tried to cover that corner with foil but had problems with beans getting wedged between the foil and the popcorn maker.
Hello All
I have managed to stretch the roasting times out to about 6 mins by drilling a few holes in the side and top of the popper, placing the popper on an angle and roasting in the early evening when its cooler and I am finding that the resulting coffee has less of the sour/fruity taste and more of a rich chocolately taste. I purchased an infrared temperature gun from jaycar to measure the temps as I figured a thermocouple in a popper may give a reading of the air temp instead of the bean temp. So far so good and I am having a great deal of fun trying out different roasting profiles in the cup
Yes I too just bought this coffee roaster and noticed it runs quite hot:
I dont have scales but:
First roast: one scoop of the supplied measuring cup. first crack at around 2min 10 secs. Didnt notice a gap between first and second crack but stopped at roast at 5min when things started smoking a bit and was violently popping. Well into second crack.
Second roast: drilled about 30 holes in the clear plastic cover, running a pedestal fan on max. Two scoops of beans. Me thinks too much beans as was not agitating well. First crack at 2min 30 secs. Finished at 5 min again. A little patchy this roast but most beans probably just past first crack.
Next attempt think maybe: 1.5 cups of beans same setup.
Interested in other peoples reports.
Hi Guys,
I think the most accessable solution would be to increase the volume of air passing through the popper, as already suggested.
My suggestions are:
1. Enlarge the small louvers towards the base of the oven chamber.
This could be done by carefull use of a blade screw driver or similar.
2. Stir the beans using a wooden chopstick or stick right from switching on until they are able to maintain this movement due to the poppers air flow. Stir in the direction of the poppers natural vortex and hopefully stiring will not be required for long into the roast as during the roast the beans density will decline.
Good Luck Roasters
Lindsay
Ive tried ice (not dry ice) and there seemed negligible difference.
As mtee said, drilling holes is a very effective way of cooling down a popper therefore lengthening roast times.
I dont think poppers "break in".
I bought a Kmart one to experiment with but havent gotten around to that.
Just had a look at it.
Typically it could do with more air intake holes and Im sure some holes towards the top of the body would help dissipate trapped heat.
