First roast a CS6 I think - done according to the book with the Peru beans I got in my starter pack - 250g on the 1/2lb P2 C setting. I dont think it got to first crack - cant rweally be sure actually as I have never roasted before.
Second roast a CS8-9 I believe. I definitely got to first crack (or was it second?) - it weas manically cracking. 250g on the 1lb P2 C setting. I pressed cool when I saw the first signs of smoke - I probably was over-reacting but as a first time newbie roaster you never know right?
So I also had the err2 on the Behmor doing the dry burn and Andy fixed me up with it but both roasts were done prior to the fix - will the fix make a difference to the results above or is it unrelated?
Second, I also got the multimeter thing with the Behmor. Do I really just drill a hole through the left hand side? Dont I need a glan or a gasket or anything? A bolt to hold it in place? Anything? Or does it just kinda sit in there? I assume theres no electronics in the specified drilling position to worry about.
