My first roast
  • My first roast
    Recently purchased a Behmor and this morning had my first go at roasting coffee.
    315g Peru Ceja de Selva Estate, settings were 1lb/B/P2
    1st crack at 5:00 and silent by 3:00, 2nd crack at 0:40 at which time I hit the cooling button, after 1 min of cooling I opened the door ajar.
    Turned out around CS9, basically no smoke at any stage, next time ill use 1lb/C/P2 to try avoid the heat ramp up between 1st and 2nd crack.
    Tasting notes to follow in a few days
    Re: My first roast
    That is a really early first crack! On 1lb p2 c I get first crack at around 13 mins.
      Re: My first roast
      I believe he means 5 minutes remaining - which sounds about right to me
        Re: My first roast
        Ah ok. Im not familiar with 1lb P2 B setting. For me first crqack is around 10 mins remaining..
          Re: My first roast
          Yes times stated was the remaining duration for that program.
          Translated this means 1st crack after 15min and 2nd crack after 19:20.
          The only difference between the "B" setting and the "C" setting if you select 1lb/P2 is the duration, which goes from 20:00 to 22:30 if the manual is correct.
            Re: My first roast
            Very even roast for your first try. This bean is a good starting point and this looks good from the photo.
            Good stuff
              Re: My first roast
              "C" goes to 21:30 with 1lb P2 setting. But yeah - you roast looks nice!
                Re: My first roast
                Some brief tasting notes...
                Balanced acidity with cocoa and caramel notes, makes a pleasant latte, a bit lacking in body, loads of crema but collapses fast.
                The mrs said it was the best piccolo she has had in a while 5 days post roast.
