Newbie needs advice
  • Geoff_L
    Just checked my notes and I've done several 200gm roasts of the Ethiopian Gambella Sundried.
    They were all done on 1/2 P2 B and ranged from CS8 to CS10 depending on when I hit "cool".
    I really like this bean and also use it a lot in blends.
  • Burkeyboy
    Cheers. Will check it out.
  • Javaphile
    Lots of discussions about it here: http://coffeesnobs.com.au/cup-tastin...tml#post378317
    Java "Up over there" phile
  • Burkeyboy
    started a topic Newbie needs advice
    Newbie needs advice
    Hi All. I need some help with roasting some Ethiopan Gambella. I am using a Behomor and have had good success with the other 2 beans I have roasted, Peruvian organic and Tanzania Machare Estate. I read how the Ethiopian would need a lower and slower heat application and that they have a really long first crack. I assume the Behomor only has set programs and you can't manually adjust? I selected 1/2 lb on P4 which appeared to have a slower heat application. I normally wait until a bit into second before hitting cool depending on how the colour of the bean is looking ( I like a darker roast). The beans appeared reasonably dark early into first crack, but I let them go for a while before cooling as first crack was still quite rapid. I left it too long and the beans are very dark and oily (I guess burnt). I should have cooled earlier but first crack appeared nowhere near finished. My question is, are these beans suitable for the pre-programmed set up of the Behmor? Is the heat too hot, or should I have just cooled earlier? I like what I've read about these beans and would love to get some success, any ideas> Steve
