Roast Levels - Correlation Between American Terms and CS Terms
  • Roast Levels - Correlation Between American Terms and CS Terms
    Hi Roasters,
    I'm tryng to correlate the roast level numbers between the american based terms(City, Full City etc) and the CS Numbers
    I have put them down as follows. Would love it if you guys could comment
    Numbers at the begining correspond to numbers in the NON coffeesnobs image below, then name, then CS number
    9.City (CS6)
    10.City + (CS7)
    11.Full City (CS8)
    12.Full City Plus (CS9)
    13.Vienna (CS10-11)
    14.Full French Roast (CS12)
    I have included Samples from CS and an Prominent US website (Not going to provide backlinks but im sure know which one it is)
    and
    For some reason i cant edit the post above.
    I have put the following spreadsheet together, it now has correlation between the CS numbers and others that i have found. Also it has rating against how the roast affects Taste, Aroma etc.
      Really helpful... I'd love to hear whether the super experienced roasters agree with your levels especially as CS numbers relate to second crack.
        The ability to edit is only available for a few hours after you post. :-)
        For instance I posted this morning, around 11 am, edited the post a bit after 2 but can't edit now, at 5.45 pm.
        Cheers.
          chokkidog... I was hoping that you might be one of those super experienced roasters who might comment on CS numbers versus second crack and perhaps approximate bean temp? (he types hopefully)
            Every bean is different. Of the beans I roast on a regular basis, one will hit 2C at just 209 C, most hit 2C between 215-218 and there are a couple that hit 2C at 221-223 but I have never come across a bean that hits 2C beyond 223.
              Interesting... I've roasted about 20 different types of bean thus far and haven't seen as much variation as you have. I've never seen one hit 2C below about 219.
                Well done attempting to try and document something that may help de-mystify some of these parameters and that others may find useful. I would suggest however you stipulate its your interpretation and no doubt intended to be a continual "Work In Progress".
                From my experience:
                The stated temps look a bit high based on my using both a Hottop & Proaster. My interpretations of the CS numbers are also quite a bit different. My CS9 is generally closer to start of FC.
                I also think the Cracks and the colour may not be quite as closely tuned together, although often used as milestones.
                I imagine temps will depend on the measurement setup etc, and are more probably relevant from a relative situation within your own setup, especially for many home roaster setups rather than absolutes.
                And yes as mentioned I find the different beans make a difference.
                The temps will also depend on the roast profile.
                Grahamk
                  The lowest 2C readings are for decaf coffees, which happen to have lower moisture levels than regular beans. And... I roast on a commercial drum roaster so perhaps that makes a difference. Of the 100+ types of beans I have roasted, 90%+ would fall into the 215-218 C start of 2C range... with 1C usually starting around 190-193 C. Also, keep in mind that everyone's machine will read slightly differently, depending on the type/quality/calibration of temp probes used, the placement of said probes, the offset value of the thermo/datalogger, the airflow etc...
                    I don't put myself in that category, I like to roast and I like to share, sort of sums it up.
                    Even tho', to an extent, roasting is a numbers game, everything is relative and not a lot of the hard and fast
                    can be transposed from one roaster to another.
                    I agree with Vinitasse and Graham and also echo 'good job' sentiment but
                    if I followed a chart stuck to the wall I would hit myself out of the ballpark and out of the game.
                    For the most part, my range for the very start of 1st crack is 195°-198° and start of (audible) 2nd crack 218° - 221°.
                    If I didn't watch what I was doing, I would have missed the start of 2nd crack, the other day, when it started, (for a new bean), at 216°.
                    My figures are slightly different to Vinitasse's, highlighting the relativity. Our figures say something about roasting in general
                    but the detail says more about thermocouple probe placement, roaster design and manufacture, drum material and roasting style.
                    (oh yeah and the beans we're using and the outcomes desired)
                    Cheers.
                    Last edited by chokkidog; 12 September 2013, 08:12 PM. Reason: others posted while I was typing!
                      I don't count myself as very experienced, but I think that the temps also look high and that the CS numbers look low compared to roasting position vis-a-vis cracks (e.g. I see CS10 as a few seconds after 2C for most beans).
                      Lots of good info thanks. Really interesting with regard to decaf, moisture levels and lower temps required for 2C.
                        Hmmmm…… been thinking ……..
                        I do some pre-blends but group beans according to moisture, hardness (altitude) and desired roast level.
                        I have noticed if I roast an El Salvador, (for instance) with 30% (approx) of an Indian, the 1st and 2nd
                        cracks are 195° and 119°, respectively. If I then roast a pre blend of the same El Salvador with 30% of a washed
                        high altitude African then 1st and 2nd cracks are more like 198° and 221°.
                          Sorry that should have read: "My CS9 is generally closer to start of SC"
                          GrahamK
                            Morning all
                            I've never been big on trying to match the colours and predict the taste - there is so much other stuff that impacts final flavour!
                            You can turn a bean to CS11 in 3min in a popper - and it probably won't be roasted, so will probably taste bitter & sour :-)
                            But an identical bean slow roasted to that colour using a longer profile will be completely different.
                            I rarely take any bean beyond 2C (CS8-9 if you must :-) - but can vary the taste hugely by changing the profile that leads up to it …
                            Just my 2 bob :-)
                            Matt
                              How good is this discussion!
                              It’s exactly what I was trying to achieve I have no idea how the colours/names/temp match and i thought if i start a thread, that would allow for some "expert" advice that will allow me to fine tune the numbers in the chart
                              In my limited (VERY LIMITED) experience, I have found that although coffee roasting is more of an art than a framework/process. There are some "Basic" guidelines that can be used.
                              The questions i have being a new roaster, are questions like.
                              When should First Crack be starting?
                              What is the taste difference going to be like between FC and SC.
                              Have I taken this too much into SC?
                              Ok, so this is roasted, Is it CS8? Is it CS10? is it a City? Who knows...
                              Have a taste.. Oh wow. that’s kind of bitter? what did i do wrong? Or oh no.. that taste sour? or is it bright? i don’t know but what can i do to change it?
                              The biggest problem is that most of the experimenting is based very much on taste, but what happens if you don’t trust your taste? How i know that what i perceive as "good" is actually good.
                              The aim of this chart is to try and correlate some basic ranges that should be in ball park, this is my basis for starting, and from there as with anything people will then start adapting as per thier own preferences taste etc.
                              A final point i am trying to address is, there is a wealth of information on the net. And as i found 1 site/person will have FC at 195 the next has it at 200/190. There is a lot of variation.
                              Also, because of all the different placements of the temp probes. The numbers can be different. but what i used was "avg bean temp at termination of roast". Im hopeful that, that will be pretty standard.
                              I can then use the information you guys provide and try and re-adjust the chart to more closely resemble reality.
