Hi Roasters,
I was having a play around on the Corretto yesterday and I thought I would try roasting a couple of different batches of PNG Wahgi, one on fan speed III and one on II (I have a Bosch 630) to see what the difference, if any, would be. I tasted the roasts today and found that already the lower fan speed has a much less bitter taste and more sweetness than the higher fan speed. Unfortunately though, this wasn't the only difference between the two roasts, the slower fan speed roast was also about 3 minutes longer and had a much slower/gradual rise to BT 150deg...so I will have to do some more experimenting/limiting the variables before I can be sure it is the fan speed that is the difference between the two.
I did a bit of a search but couldn't find anything referring to the benefits of either high airflow or high temperature...does anyone have any advice or suggestions on this ? I would have thought that a higher fan speed, allowing a lower heat would be more gentle on the beans or is it the other way around ?
Dave
Dave
