next roaster sensor: a Microphone
:-D HaHa. Good typo!!
Saw this article in 'Roast' a couple of weeks ago.
Interesting, especially for people who roast and whose hearing is deteriorating, it could be hooked up to a video display monitor
so that the progress of first crack can be monitored by the frequency and amplitude of the visual sound spikes. It would also help
pinpoint those very first snaps of second crack which can be hard to hear in a big roaster, then you could easily adjust your profile to avoid 2nd
if that particular bean profile was hovering around that point.
I had a chat about it with Andy last year, even googled high temp mics to see what was available.
automated roast monitoring research
Cracking the code for a perfect coffee
Can the cracking lead to an automated roast monitoring technique?
Cracking the code for a perfect coffee › News in Science (ABC Science)
Barry
- Dec 13
- 968
- Brisbane
- Bulk brew; Pour over; Double Ristretto; Oat Milk Cappuccino or Piccolo
- Send PM
I used to work with acoustic altimeters and acoustic hydrophones back when I was a commercial diver. The transducers are rugged - they might be modified to place into a sealed unit sort of like a HX onto the outside of a roasting drum (as near the rotating drum as possible). The membrane might be swapped for something more heat resistant. They're relatively inexpensive and, well, you wouldn't need the helium voice unscrambler unit anyway. It's doable.
I was thinking of placing the mic inside the drum, mounted on the faceplate, like a thermocouple probe, probably above the bean mass and under the exhaust outlet.
Filtering base line noise would be easy enough, given suitable software; there are mics used in high temp food manufacturing.
In reality tho' experience, sight, smell and Andy's software will do, just fine.
The mind wanders sometimes............... ;-)
Originally posted by chokkidog View PostA novel idea? Haven't yet seen a roaster with a high temp mic in it, hooked up to a display or a PLC.
If I've thought about it, chances are someone else has attempted it (like all my good ideas)
Like a dog with a bone. Get yourself next to a roaster as described, with all the noise of drum and fan motors, maybe a second or third roaster
also in roast mode, an extraction fan, air conditioner, destoner, vacuum bean loaders, forklift.
Some beans are whisper quiet even at first crack, the first scouts of second barely audible even through the sampler tube.
I'd put mine inside.
