I have just received my data logger and downloaded the roast monitor program but, when I plugged it all in and tried to open it I got a balloon with this message "Roast Monitor encountered the following error & could not continue.. Cannot run program " RawMeterReader": Create process error = 2, the system cannot find the file specified. Any assistance would be greatly appreciated.
Problem with Roast Monitor Program.
Did you run the Roast Monitor installer with Administrator permissions and let it install to the default directories? If so check to see if the files were actually written to the appropriate directories per http://coffeesnobs.com.au/home-roast...tml#post513175
If there's any doubt run the Roast Monitor installer again being sure to 'Run as Administrator' and accept all defaults during the installation.
What OS are you using?
Java "Aren't computers fun?!" phileToys! I must have new toys!!!
I am set-up as administrator, I have downloaded Temperature Data Logger Thermocouple and RoastMonitorUSB software, 4 times (removing each time befor I reinstall) and I still get the original message. I am not given any defaults during install other than to create directory ( (c:\Program Files(x86)\CoffeeSnobs), using windows 8, 8.1 upgrade.
Originally posted by Javaphile View Post...check to see if the files were actually written to the appropriate directories per http://coffeesnobs.com.au/home-roast...tml#post513175
Java "Listening to the echo" phileToys! I must have new toys!!!
The program (x86)\CoffeeSnobs\ contains the following files and applications:
Uninstall, application
Roast Monitor, windows batch file
Release Notes, open office doc.
READ ME, open office doc.
RawMeterReader, application
Introducing RML, open office doc.
Data Logger, Jar file
C
cslogo, GIF image
cslogo, bitmap image
scCupLogo, ICO file.
When I ran RawMeterReader exe. as administrater, it opened and ran fifteen columns of numbers to fill its page, then they all turned from double numbers in each column to two zero's in each column . When I tried to open Roast Monitor, I got the same original message, I then ran it again and again only got fifteen columns of double zero's. I tried to trouble shoot the problem and tried compatibility mode, but got the message that it was not compatible. Any suggestions would be appreciated.
It appears all the files are there so the installation process seems to have worked.
The only thing I can think of is that it's not working for you because the meter has not installed correctly.
These are really obvious and assumed to have been done but for the lack of anything else to suggest:- Are you are turning the multimeter on and to the temperature position and can see the temp displayed on it?
- Are you plugging the meter directly into the computer with no extension cable used?
- Is the cable plugged into the meter all the way?
- Have you tried using a different USB port?
I don't know about using Win8 but running Win7 here even with-out the meter plugged in Roast Monitor launches and brings up the usual window. A windows error msg saying "ConsoleApplication1 has stopped working" pops up at launch. Closing it via the red X leaves Roast Monitor running with a message with-in the Alerts box that no meter was detected followed by several other related errors.
With the above checked off the possible issue list I'd say:- Something in your OS (Security setting of some kind?) is getting in the way.
- There's a problem with the USB port(s) on the computer.
- There's a problem with the USB cable.
- There's a problem with the USB port on the meter.
- There's a problem with the meter.
Java "All thunked out" phileToys! I must have new toys!!!
Yes, I have had the meter plugged in and turned to C and the RS232 pressed in and the symbol on the meter screen. I have opened device manager and checked if it said it was working properly and it did, so I removed the usb plug and was told to reconnect it, did this and it went back to telling me that the meter was working properly. Looks like I need to find an old laptop and use that for roast monitoring, but at least for the moment the data logger is working just great giving me the info I need for roasting, thanks to all for your ideas.
