Andy (or anyone else). You're supplying the stainless temperature probe in this kit now (so you need to change the mounting instructions in the diagram in the first post for the larger hole required).
How is this mounted? I tried just screwing it into the outer case but that won't work as the thread doesn't go all the way to the nut so it won't fit snugly. Do you use a washer between nut and case? Somehow put a nut on from inside? Or do you just poke it through when using without attaching it?
