Hi All
Thought I should make potential Behmor upgraders aware of potential of "cooking" their roaster, as I have done.
I think of myself as reasonable technically proficient and thought this upgrade would be a doddle after watching appropriate videos.
All went well pulling the machine down and then putting in the new panel and putting the machine back together-WRONG!
When plugged in and turned on motor started, interior light turned on, lights on panel came on. I thought it was doing some sort of "pre-flight" check.
Next thing electrical smoke/smell and lights out.
After tears, swearing and cooling off (me not the machine) I went back and had a look. I had managed to plug the small connector, not into where it should have gone, but into another "compatible" two pin socket where the fan plugs in. My roaster did not have a fan as in the video I watched.
The main board now appears damaged as when the panel is plugged in correctly I get motor working, lights and no control.
Totally my fault for being careless in not following the steps I took in dismantling in reverse order, but beware there are two options where you could plug in the small connector.
Now to decide fix or replace as I have had many kilos of great coffee produced by the Behmor.
