Just looking for some advice on what I'm doing wrong. Virtually all the roasts in my KKTO appear to have inner scorching that I just can't seem to resolve.
It's an arcosteel pasta pot set. The inner roasting volume is 6 litres so would be about 7 litres with the turbo oven on top. It's a rank arena 1400watt oven. I typically roast 600g. Usually I drop the beans in at 200 degrees but the drop temperature doesn't seem to make a difference to the taste. I've tried cold starting the roaster which was probably the worst of all. I've increased batch size to 800g with better results but still a little ashy. Externally the beans look ok its only when they are chewed on that the ashy flavour is revealed and fairly consistently so. I'm stopping the roast usually just on the start of second crack or about 220 degrees. I've started to drop them about 213 degrees and hasn't seemed to have changed the smell or taste.
I've attached the profiles on the graphs to see if anyone has some idea where I'm going wrong or what I can try.
