Hi again all.
First bread maker. 450gram of the Monte Carmelo. Waited for the fast knead cycle and went for it with the HG set at 650 C 9 cm away from centre of bean mass at about a 30 degree angle. First crack was at about 10-11 mins and then about 30 second into the first I dropped the temp to 500C, but it seemed to be accelerating a bit fast still, so I dropped it back to about 450C and second crack came at about 20 mins - and I pulled them within 30 seconds of that. I noticed in the first part of the cycle - before first crack - that a couple of beans were getting better done than others. They seemed not to get sucked down into the blade. I tried a couple of hand stirs as well just before first crack and after (only for about 5 seconds each). I ended up with a consistent batch of beans, but I have pulled out about 6 that were charcoal - is this normal. I noticed when I did my first HG the other day by hand - about the same size - that there were no charcoals - so perhaps if you are willing to stand there and do some manual work there is better control.
Anyone got any advice about the BM and HG settings and method that I am doing that might see no charcoal and even longer time between first and second? Do I need to drop it to say 400 degrees C. In the big stainless bowl there would be a lot more heat loss than the tight tall confines of the BM, so perhaps I need to go lower for the BM for second crack than when doing it manually.
