Do all beans go through first crack?
  • sprezzatura
    Originally posted by Dimal View Post
    Good info to be found on the Sweet Maria's website...
    https://legacy.sweetmarias.com/libra...e-degree-roast
    Roasted Coffee Comparison: Surface Color and Texture Versus Ground Samples
    Many other resources located here too, so search away...
    That's a great piece they did; another on roast depth with the Behmor is great!
  • DesigningByCoffee
    That's why using a temp probe is so handy. Some of the most amazing beans I've ever roasted were the Maui Mokka from a few years ago. They were tiny peaberry style beans and there was no 1C that I could hear. But played it by the numbers. Had to drop a few degrees earlier as 2C came on, but easily done when you know the 'zone' you are hunting for.
  • dan77
    Sight and smell tend to give away where a roast is at if the cracks are not that audible. Use all the senses except touch but add common sense and you'll be ok no matter the bean.
  • MrFreddofrog
    Ok, dumb question coming so be warned, how can I tell if FC occurred just by looking at the beans? I've always just listened for it.
    The 3 or so pops I did hear at the start of FC were quite distinct so I was expecting the rest of FC to be similar. Obviously wasn't the case.
    Btw SC was quite audible, about 3 seconds of snap crackle pop before I realised I was listening to SC and not a late FC
    Some "Peaberry" beans (and normal ones too) have a very quiet 1st-Crack and may be difficult to hear when in progress. If the batch made it as far as 2nd-Crack, given the profile you have recorded, then they certainly achieved 1st-Crack along the way. You should be able to tell by inspecting the beans though...
  • MrFreddofrog
    started a topic Do all beans go through first crack?
    First time roasting Brazil Peabody and FC was all but missing. I heard about 3 pops at 11:38 and that was it, nothing.
    So do all beans go through FC (or SC for that matter)?
    Maybe I did something wrong? Below is the profile. 100% heat and charged at 150C chamber temp, drop to 75% at 100C BT and then 50% at 200C BT. I kicked it back up to 75% trying to "encourage" FC by adding more heat but nothing heard till SC. Charge weight was 250gm, ambient temp 14C, humidity 75%.
    Thoughts?
Name:	046 2016-08-08 Brazil Peabody SCs+0.03 19%.png
