Colour evenness the fluid bed is usually better
...but taste...
drum wins every time. More body and more flavour depth in the result, fluid bed roasts are nearly always "soft".
Yes- convection only roasts are not the same as roasts which incorporate a proportion of conduction.
It's not really clear to me why conduction would be inherently different. The inside of a bean is influenced only by the bean surface conditions - assuming they were the same, the mode of heat transfer is not relevant.
So, what I would love to know is what is the difference in bean surface condition (between drum and fluid bed roaster)? Perhaps it is simply a matter of changing the operating conditions in a fluid bed roaster?
I would imagine that air velocity has a lot to do with it. In a fluid bed roaster the air is moving a hell of a lot faster which would lead to a far faster drying phase as the moisture is literally stripped out of the beans far more efficiently than it would be in a conventional drum roaster. Kitchen ovens demonstrate this as recipes always call for shorter baking or roasting times in fan forced ovens. And... a quicker drying phase, shorter roasting time and, most likely, lower moisture content will ultimately result in roast (and flavour) profiles quite different to those from drum roasters.
" And... a quicker drying phase, shorter roasting time and, most likely, lower moisture content will ultimately result in roast (and flavour) profiles quite different to those from drum roasters "
I once stretched out a roast to over 20 minutes in one of my Frankenpoppers, with a slow ramp up, much as Matt and Mal do in their corretto's. As I recall, it was very even, but it was the worst result I had from that bean.
My palate lacks the ability to describe it better, but flat, lifeless, bland, are all terms that spring to mind. I needed no further convincing that hot air roasts need to be kept shorter than most other methods.
Never used a "longer" profile with any of my Poppers, for the very reasons you discovered "deegee"...
Found that the optimum roast duration was between 10-11 minutes for 95% of all the beans I tried.
There's a lot of sense in what "Vinitasse" outlined above, in my opinion...
This is pretty much in line with what I suspect. In theory, it would be possible to compensate by control of humidity and temperature...
My experience with convection roasters leads me to agree with Andy. They produce a softer flavour, though I sometimes countered this with blending in some dark roasted Ethiopian beans.
I really wished I had read this thread before I dropped 1600 dollars on a 120g roaster. I thought they were supposed to be superior roasters from what I was told elsewhere. The flavours are "softer". Damn!
Would adding robusta beans help this problem of muted flavours Andy?
Well, that's the problem right there.
CoffeeSnobs community is all you really need
A popper is $5 in a second hand store, around $20 brand new yet glorified poppers reach well over $2000. Someone builds them and someone buys them.
You can get a very even and pretty looking roast on any fluid-air roaster but typically the same bean roasted in a drum/oven with a mixture of hot air and radiant/convection heat will always have better body and the potential of better flavour development.
There will be nothing wrong with your new roaster except the small volume might eventually drive you nuts.
I suggest use it, and enjoy it till it does.
