Roast Monitor Scales on Y and X axes
  • Roast Monitor Scales on Y and X axes
    Hi All
    Is it possible to include scales on the Y (Temperature) and the X (time) axes?
    If you're talking about this Roast Monitor they're by default already there and are configurable via the preferences.txt file.
    Java "Say what?" phile
    Toys! I must have new toys!!!
      Yeah, what he said!
      Added to that...
      Using the default configuration the time is 0-30 minutes and the temperature is 0-300C
      Each small square is 1 minute wide and 20C high.
      Each bolder square is 5 minutes wide and 100C high.
      With use it's really easy to look and see 3 x bold wide (=15min)
        Thanks for the reply. Would it be possible to have actual numbers at the X and Y axes displayed For example X-axes 1min, 2min and so on OR at the Y-axes 20C, 40C and so on
          Don't think it will ever happen.
          Early prototypes of the software had it and it was way too messy and cluttered, even worse on small "netbook" screens that had trouble with overlapping.
          You have live number for the temperature and time under the graph, and as I said, with enough use the squares are pretty obvious.
