Roast what first?
  • Roast what first?
    I bought one kg of PNG PSC A and one kg of the PM blend from fivesenses coffee. Which should I roast first? I might try roasting for the first time on my new popcorn machine.
    Re: Roast what first?
    Hi Amber, if you roast the NG dont go too far, I roasted NG Fairtrade past second crack and they were overdone and bitter, next roast I went to start of 2nd crack and they were spot on.
    Give it a try and then roast the other beans. Rest them for a couple of days to degas, but I usually sneak in a test brew before then!!!!!!!!!
    Good luck with your roasting, run a fan over the top of the popper to cool it down and disperse the chaff and hopefully extend the roast as poppers are fairly quick...............
    cheers
    Greenman
      Actually, I much prefer to pull these beans well before 2nd-Crack at around CS Member Card 9. For me, this is the peak flavour point with lots of fruit and soft spices like Cinnamon and Cardamom. Pays to experiment a bit until you find the roast level that suits you best ,
        Thanks guys for the tips. How do you get a CS member card? is the one with the different roast colours? ...shit after I started joining this forum Im wanting more and more gadgets n what nots for my silvia
          Gday amberosw,
          Welcome to CoffeeSnobs by the way [smiley=thumbsup.gif].....
          If you buy some beans from our next BeanBay (see top L/H side of the page), before you checkout go to the "Other Stuff" button and then add the CS member Card to your order (first ones free), and then Checkout. Itll be included with your bean order then, after which youll have the common terms of reference that a lot of us use when comparing roasts. Another one of Andys great ideas 8-).....
          All the best,
            Ive roasted the beans. The first batch I think is underdone. The second batch looks good initially but after resting for one day it looks oily. Why?
              Oil appearing after resting is common.
              It is simply an indicator of a darker roast.
              If you take a roast into rolling 2nd crack, you would probably see oil on the beans when you pulled them from the roaster.
              When you do a lighter roast, oil may appear in the days following, but if it is a very light roast, not much(if any) will show.
              In short, its normal.
                thanks fatboy, thanks everyone for being so helpful.
                just finished another batch. keep smelling chaff air now even though its all over.. *smokey eyes*
