Heat Gun
  • Heat Gun
    Im about to get started on a Corretto. I spent hours reading threads on the subject, but before I did, I happened to be in Bunnings, so bought a heat gun. When I got home, I proceeded to read that the one I bought was a dud. ($20 - A Bunnings brand, I think) So, I thought Id take it back and buy a Ryobi, which I remembered reading was good, when Im in the neighbourhood next. Eventually, I found a BM at Cash Converters, so the heat gun became more urgent. I went there today, and discovered that there were two versions of Ryobi. At first, it seemed to me that the only difference was that the more expensive model gave your all sorts of gadgets not needed for coffee roasting. But, the guy (may have been a good salesman) said that the more expensive one has adjustable heat settings and a stronger motor. So, I stood there scratching my head. He then showed me the GMC Platinum HG2000K, which he reckoned was the tradesmens model and a lot sturdier than the Ryobi. It was also $10 cheaper than the more expensive version of the Ryobi, so I bought that one.
    I now cant find the thread that discussed heat guns, and dont really fancy reading everything all over again, so I wonder if you could advise me if this one is any good (also has 2 years warranty) or should I take it back and get the Ryobi? And if the Ryobi, which one?
    Re: Heat Gun
    Get the Ryobi with the adjustable heat settings. If you do find that heat gun thread, youll see that an awful lot of GMC heatguns have failed, including mine. Some people dont care about the adjustable heat setting, they simply move the heatgun closer or further away on its stand. I find moving the heatgun awkward, and find greater consistancy in leaving the heatgun at a fixed height and playing with a dial.
    I was unable to get the Ryobi when my GMC died some months ago, I have the equivalent Makita now and Im happy with it. Bosch also has a heat adjustable model heatgun, and Im sure there are some CSers who find them good as well.
    Hope this helps.
      Re: Heat Gun
      Hi Judy, great to see you are joining the Corretto club. I have the Ryobi from Bunnings with 2 speeds. I only use it on the high setting and adjust my heat by moving up and down and stainless shaft with locking nut. Have done 55 roasts now without a hiccup. I use a small $10 cooling fan from Bunnings to cool gun and disperse chaff, I think this helps prolong the life of gun. To sum it up--no complaints from me on the Ryobi.
        Re: Heat Gun
        Hi Judy
        Welcome to the world of corretto
        I have the Bosch with an adjustable temperature and have had no issues with it even after 150 roasts.
        Mal
          Re: Heat Gun
          Hi Judy,
          My first buy was the GMC Platinum and brought it back twice and decided to go the ryobi route (2 speed only). Since then I havent looked back. Roasted probably around 100 or more roasts without troubles. I also use a small fan blowing on the heat gun to prevent overheating, especially good if doing back to back roasts.
          The thread you might have been looking for was the HG reviews. Check here http://coffeesnobs.com.au/YaBB.pl?num=1164000407
          The Ryobi temperature control will give you more options but the 2 speed is still sufficient in getting a good roast done.
          Good luck.
            Re: Heat Gun
            Tradesmans model the GMC HG definitely isnt. In a space of 6 months, Ive had 2 GMC HGs fail on me. The only reason I got themtwice was because of the variable temp function to control the heat. Now Ive modified the setup to have variable height instead which works better than the HG variable temp method so I wont be getting another GMC HG.
              Re: Heat Gun
              Hope this helps.
              I also have the Ryobi with Variable heat dial. What temperature do you use from 1st to 2nd crack? I assume both temperatures are at high speed?
                Re: Heat Gun
                Thank you for that, back to Bunnings I go. ;D Actually, you may be able to help me with something else. I actually looked for a fan while I was there (accidentally discovered a new store, opened the day before, at Port Melbourne - pretty small, compared to some of the others) could only find heaters. Would you be able to tell me the brand of fan you got? Also, can you lay it on its back, so that I can cool the beans with it too?
                  Re: Heat Gun
                  Originally posted by The Goodies link=1208006688/0#4 date=1208055928
                  Hi Judy,
                  Thank you for that - that wasnt the one, I actually never saw this thread, so it was helpful
                    Re: Heat Gun
                    Judy - a bathroom extractor fan can be easily ounted on its back and the Arlec models are usually between $14-$20 each - you can buy a self install model that comes fitted with a standard power plug that you can just plug straight into a power board. It can be mounted in a bucket - you like me you can build a little frame to hold it.
                    As for heat guns - Ive also had two GMC models, replaced under warranty then decided to go with the Bosch digital model - very nice roasting.
                      Re: Heat Gun
                      Ive included a pic of the $10 fan from Bunnings, I use it to cool hg and disperse chaff then place under cooling rack.
                        Re: Heat Gun
                        If you start to roast amounts of 500g or more you might want to think about the extraction fan option for cooling. The small fans are ok to blow chaff away and have a continuous breeze flowing over the HG but to cool the beans quickly you will need to something with a little more blowing power.
                          Re: Heat Gun
                          I have actually seen pictures of this kind of set-up and really like it, but you then cant use the same fan for blowing at the HG & chaff during the roast, can you? As I live in a flat and the whole set-up will have to be used on the balcony and I will somehow have to find a home for it indoors when not in use, I am trying to make the whole thing as compact as possible and have as few added bits as possible. Oh, how I envy those with sheds.
                            Re: Heat Gun
                            You can always put it all on a trolley and wheel it in and out as needed. Do a search and you should find some great ideas. I have put mine setup on a small old student desk on wheels so is moveable.
                              Re: Heat Gun
                              Mount the fan in the side of the bucket rather than in the bottom. You can then use it to blow over your roasting setup.
                              Java "Ideas R Us" phile
                              Toys! I must have new toys!!!
