Crazy popper results for different beans
  • Crazy popper results for different beans
    After a few successful and what I thought were unsuccessful exercises in my Crazy Popper I have decided it is the beans and not me.
    I have found that roasting the Nicauraguan High Grown Blend will always produce an uneven roast.
    The Indian Mysore Nuggets take longer to roast and stay relatively light in colour.
    The Indian Kappi Royale are the easiest to get consistent colour
    I would add pics if I could figure out why it wont let me attach them.
    Re: Crazy popper results for different beans
    Hey Kevviek....
    I am also using a crazy popper. Have not found that the Nicaraguan HG roast is uneven. Am actually finding it is a superb bean to use!
    Out of interest... what are your roasting times? Are you in a cold location?
      Kevviek
      File is too big
      Save photos as jpeg image and reduce the size of the photo b/4 attaching
        Ok, have worked out the attaching bit.
        Temp in Melb is cold this time of year. Im roasting in the mornings, so probably 10-12 degrees max outside.
        I have just about got the FC/SC worked out, am using a small bin to put the popper in to get things moving, then take it out after first crack. Am now doing around 6-8 minutes to FC, another 5 or so minutes to SC.
        Up to now everything is done by sight and sound, no temperature probe and in the cold weather no risk of burning the beans. Have found that the oils are coming out after 3-4 days and only a couple of beans in a batch have the pits/discs coming off.
          Hmmm...
            Kappi is even roast, Mysore is not too bad, Nicaraguan is very uneven. This is fairly consistent even with smaller batch sizes so I am guessing some beans are more sensitive to the roasting conditions.
              Gday kevviek,
              Nice job there mate [smiley=thumbsup.gif].... The roast times are really excellent too, especially for a popper. The Kappi looks to be very nicely done but the other two are possibly a bit light. Hard to tell of course with computer monitors and camera flashes, etc. What would you grade them at using the CS Membership Card? A much better way to compare them 8-).... Looks to be a few extra dark beans in the Nicaraguan batch mate. Did the roast stall slightly at the start before spinning up and agitating?
                No stalling in terms of spinning, they were happily bouncing around the whole time and usually I give them a little extra with some chopsticks as well to help the chaff come out. Thats why I have been perplexed as I have done around 15 roasts now and get consistent results for each type of bean. I have done 6 batches with the NHGB and not one even roast, but the other beans are fine. The Mysore are my favourite ATM, and I am certain I am getting them well into SC now but they dont get as dark as the other beans for the same roasting time/conditions.
                  Thats good then mate.... It must be an idiosyncrasy of these particular beans; I dont have any so have no appreciation of what a typical roast batch should look like. If they taste good in the cup then, thats all that matters.... 8-)
