Learning all over again
  • early_morning_
    Re: Learning all over again
    one of those things, really... you never stop learning. ive had my machine close to 12 months now and im still discovering new angles and positions to get better microfoam. todays was perfect (well, my idea of perfect :P) but i still mess up once or twice a week.
    but yeah, practice is king
  • schinckel
    I know Im only using a toy machine (DeLonghi Metropolis/1385), but Id like to think Im getting pretty good results out of it. In terms of milk, I can get much, much better foam out of fresh milk than old stuff.
    Im using the standard (plastic) attachment that came with the machine, but as the thread on this is screwed (so to speak!), I cant crank the steam up full, as it just blows the attachment off.
  • skypig
    I’ve suffered the same problem. Good foam with the $200 Sunbeam, Virtual total failure with the very powerful $2700 La Vibiemme Domobar Super Lever. Some good tips on this thread – back to the machine – practice, practice.
  • scoota_gal
    Originally posted by lucinda link=1141182898/15#15 date=1163313722
    I still get the occasional bubble blow out...
    ;D ;D ;D
    Thats a good one. Ill have to remember that term...!!
  • lucinda
    Early morning,
    I have a Gaggia classic and it took me a long while to get the foaming right too. I have had mine coming up to two years and it has been a matter of practice practice practice.
    I found that after pulling a shot, it was best to flick on the steamer switch, I usually wait about 30 secs after the light comes on and blow off a wee bit of steam before plunging the wand into the milk and have no issues after that. It took me awhile to figure it out though. I wish I had known about CS back when I got the thing. :
    I still get the occasional bubble blow out, but it is more me not paying attention to what I am doing than anything.
  • early_morning_
    been a long time... ive got it down. i got into a timing cycle - pull my shots then pump off water until the boiler starts up (ie the light goes out) then flick to steam. wait 25s, blow off steam for a few sec, close wand, put wand in milk and then open wand again. then steadily swirl the milk to perfection
    now ive PIDd my machine so i just wait til the temp read out show 140 and go for it. still need to pump some water through to make sure the boiler is happy and somewhat "pre-pressurised"....
    cheers
  • Baristacrat
    Originally posted by early_morning_ link=1141182898/0#10 date=1149134864
    first post
    just upgraded to a real machine (gaggia classic) and i know how you feel - im back to square 1. i learnt to make very nice textured milk (albeit quite slowly) on my old pretend breville but now i cant make anything but dishwater or hot thin rubbish.
    Hi Early,
    A suggestion: if the milk is hot thin rubbish then you may need to turn on the steam tip and let off some steam (literally) before you put it into the milk. : I used to have a gaggia machine, and had the same problem when I first tried to foam some milk - it was an unmitigated disaster. My advice is to pull your shots, rest them on the heated area, let the machine build up some steam pressure for a minute or so as you get the milk into the jug etc, then hold a tea towel under your wand tip so any liquid released is not all over the bench, turn on the steaming knob, when the stream of water has turned into steam, you are right to go. Just turn off your wand, place into the milk, fire up and and foam as normal. Happy microfoaming
  • Carl_B
    Dont know if this is the correct thread to follow, but can anyone tell me if the age of the milk important?  If so is it best fresh, or a few-days old, or what?
    Thanks in advance.
  • joe
    Welcome!
    If your Classic tip has a plastic sleeve over it, ditch the sleeve. The Classic makes great microfoam without it.
    I 3/4 fill a small stainless steel pitcher with cold milk (for two cappuccinos). I very slightly tilt the pitcher to one side and lower the tip just below the surface of the milk and turn on the steam. Moving the pitcher very slowly from side to side and keeping just the tip immersed, the surface of the milk after a few seconds should begin to swirl and rise slowly. When it has reached the desired height and heat (around 40-50 seconds I would guess) I stop.
    Dont worry, just practise,practise,practise...
  • early_morning_
    first post
    ive read everything i can get my hands on and im deep in the "practice, practice, practice" territory. the inability of the classic to maintain full steam pressure for more than about 40 seconds is killing me, but im starting before the thermostat cuts to compensate.... i dont think the tip design is particularly ideal. seems too large.
    it just hurts to pull these comparably beautiful shots, only to pollute them with cruddy milk
  • mbg963
    Ive noticed on the Silvia that if I spend more time swirling than frothing then I get a better result closer to the ideal microfoam. Maybe froth 1/3 then swirl for 2/3 of the time or thereabouts. The milk doesnt look like its increasing in volume as much as when I frothed heaps but texture appears much better during the pour. When pouring it looks like thicker milk, not meringue but low and behold there appears a nice foam layer in my cap....might help.
    Hi mwatt,
    Youve definitely got a great machine there by the way [smiley=thumbsup.gif]. I can only speak about my experience with the Mokita but I guess if Ive found one thing that seems to affect the quality of the foam more than anything else, it is the time taken to get things started and the milk swirling actively in the jug.
    I always try to adjust the steam output such that enough flow is being generated to get the milk swirling ASAP and then lower the jug to get the tip just below of the surface of the milk and generate the foam. Using this method, by the time the milk has approached about 30deg C, enough foam has been produced and the wand is then plunged deeper into the milk to heat it up.
    Its taken me a while to learn this particular method as I live out in the sticks a bit and receiving knowledgeable first hand tuition is more or less impossible. The thing you need to avoid is taking too long over the foam generation stage as this seems to dry it out and no matter what you do, genuine micro-foam just will not happen. Its definitely worth trying to get it right as the difference in taste is also quite amazing . Hope some of this helps out,
    Cheerio,
  • robusto
    Give the machine more time to produce microfoam without overheating the milk by keeping the jug freezing cold in the refrigerator.
    When you introduce the jug to the tip, turn the steam knob gently so you dont get an explosive blast which causes a mess and large bubbles.
    After a couple of seconds or so, when you are satisfied the steaming noise is right and you cant see large bubbles forming, progressively turn the knob.
    I like to angle the jug so the swirling milk rises above the rest of the milk at the opposite side to the steam wand.
    You can experiment with the angle, and how close the tip is kept to the wall of the jug, or the centre of it. I keep it fairly close to the side.
    When you have stretched enough, lower the tip deeper into the milk until its at the temperature you want. I keep going to about 15 seconds after the Silvia heating light comes on.
    If there are one or two unsavory large bubbles, give the jug a firm tap or two on the bench to dissipate them.
    Now, MOST IMPORTANT: swirl, swirl swirl the milk around by holding the jug and turning your arm fairly rapidly in a quick counter-clockwise motion, (the way you would to use a manual grinder of any sort, but backwards).
    Within seconds you should have a very glossy microfoamed milk absent of any bubbles.
    Robusto
  • mwatt
    Guest replied
    Originally posted by luca link=1141182898/0#4 date=1141214843
    I think that steaming milk is always just a matter of getting used to them.  The giotto has a proper multi-holed tip, which will really pay off when you get it nailed.  But, until then, you might find it awkward from being used to the gaggia.  If its any consolation, it doesnt actually get easier with even more expensive machines.  I have been lucky enough to play on some La Marzoccos and Synessos recently and they all require completely different steam wand orientations, etc.
    Yeah, i figure itll just be practise, practise, practise...
    As to it not being easier on more expensive machines- I was trained on a La Marzocco (only thing i miss about working is that baby) so it took a long time to get used to the Gaggia. Oh well, off to wasting some milk for me then...
    Agreed Luca- however the tip on the giotto can sometimes aerate a little too much. I have found that a surf back from full pressure (as you correctly state when you start) can work well...
    A 600ml jug is a walk in the park for the Giotto 8-)
    C
