I recently purchased a Rancilio Sylvia and I am not doing so well in the coffee making scene, especially when it comes to stretching milk and creating froth and Im a little frustrated and I was wondering if I may have some help please as the Rancilio manual is rather ordinary and not overly helpful.
I have tried all types of milk (skinny, full cream and even crema) and I am unable to create any foam. I have purchased thermometers, specific frothing jugs (bulge at bottom) and still no foam. I end up having to use the AA electric whizzer to obtain any sort of foam. Which as I’m sure you can apprecite is nothing short of painful?
I have used boiling water to clean the steam wand with a brand new cleaning cloth and still no froth. The steam wand is not blocked as I have extensively cleaned that and plenty of steam comes out. I even bleed off the excess moisture in the wand (from making the shot) prior to stretching the milk and still I cannot achieve any froth
It appears sometimes that the Rancilio Sylvia steam wand pressure is far too much if I open it up all the way (as I have read achieves best froth on some websites). If I open it right up, the pressure is so high it causes small waves in my milk and obviously ruins any froth.
I have attempted to tilt the jug on a slight angle with steam wand just under the milk open pressure (slightly) and allow a slight whirlpool motion and when the temp gets to 30deg I put the wand all the way to the bottom until the desired temp is reached (as this is what the man in the store I purchased it from said to do) however, this method doesnt seem to work either. I have tried the opposite as well, with the steam wand down the bottom and slowly work up until the steam wand is just below the surface of the milk until the desired temperature is reached on the thermometer but again that does not seem to help.
Im really at a loss and I am hoping that you may be able to help or certainly point me in the right direction. I am particularly interested in how other Rancilio Sylvia owners stretch their milk and the procedure they use. I am completely confident that the problem is operator error and nothing else.
Thank you for your time in this matter and I eagerly look forward to your replies.
Kind Regards,
Mick.
Kind Regards,
Mick.
