EM6910 Steam tip
  • EM6910 Steam tip
    Has anyone changed the tip of the steam wand on the em6910?.
    i was thinking of changing to a 2 hole one to see if it makes any difference to my texturing. any ideas ?
    Re: EM6910 Steam tip
    Not that I know of and personally I dont see the need.
    What problems are you having with texturing?
      i have a 6910, just started using a 1.5lt jug and found that the 6910 just doesnt have enough grunt to drive this size pitcher. The work machine (brasilia portfino) will blow the bottom out of a 1.5lt jug if I let it.
      Im thinking of trading down from my old 900ml jug to a 300ml single pour jug to see if it makes any difference
        Originally posted by 686069677070776B050 link=1267518601/2#2 date=1267526872
        i have a 6910, just started using a 1.5lt jug...
        I take it that its one of the new 3 group Sunbeam EM20730 machines? :-?
          The 6910 handles a 300ml jug just fine.
          However I think it struggles a bit with a 600ml one.
          No wonder a 1.5lt gives you grief.
            oddly enough the 6910 comes with a 600ml jug!
            Ive hear that you should also pull the plastic base out of the group head....any truth to this?
              I think its actually 500ml.
              The plastic thing is in the group handle and its called a "graeme" around here.
              The name was actually suggested by the user called DIG.
              You can read the whole story in the original post here:
              http://coffeesnobs.com.au/YaBB.pl?num=1188978543/4#4
              I believe at least one Ikon owner calls theirs Neil.
              Yes...take it out.
                thanks TG, ill check out that post
                what difference does it make by pulling out the base?
                Also, are the anti-calc filters available anywhere but sunbeam?
                  It gets rid of a place for things to grow underneath.
                  Not that I know of.
                    But does it affect the extraction at all? Why did sunbeam put it there in the first place?
                      There are a number of posts on what became known as the  "graeme"
                      TG, myself and many others have postured and commented in this post..
                      http://coffeesnobs.com.au/YaBB.pl?num=1222320381 [edit] (opps 23/23)[/edit]
                        Read the whole of the thread AM linked to http://coffeesnobs.com.au/YaBB.pl?num=1222320381
                        In a nutshell its for newb coffee makers that dont heat up the group handle properly.
                        The plastic is supposed to lessen the temperature drop of the shot by preventing it from hitting a cold metal group handle.
                        If you dont remove it... http://coffeesnobs.com.au/YaBB.pl?num=1167134124/24#24
                          well this has got off topic a bit, and to add i have removed the graeme from my handle. i now just warm up the group handle prior to pulling my shots.
                          what i was thinking with the steam tip was to try and get a better swirl or tumble of the milk in the jug, i was using the sunbeam jug and bought a smaller one but still have an issue getting the right texture for art work.
                          just thought i would try something different as when i watch the videos posted on this site the larger machines have no effort at all in milk texturing and a lot of them seam to have multiple holed steam tips.
                            Originally posted by 657974637475727061627872647C110 link=1267518601/0#0 date=1267518601
                            AND
                            Originally posted by 657974637475727061627872647C110 link=1267518601/12#12 date=1267564672
                            Yea we can get OT as further issues are raised etc
                            A two hole tip will not cut it on the EM6910..
                            Yes the bigger machines can have up to 6 holes... They are different machines and as such have a different system to develop and manage steam.
                            I never had steam issues... Slower than the bigger machines = Yes
                            At the end of teh day.. Steam arm and Tip placed at about 45% - 60% and just under the surface. This is a mix of teh steam arm at an angle and how you hold the jug..
                            Too deep and no real texture...
                            Too high and froth and bubbles...
                            Standard SB jug that came with the unit and fill to about just below where teh spout starts to take off.. Thus approx 1/3 to 1/2 full.
                            PS. Go and do teh SB training, if you have not already done so.
                              Thanks AM, you have confirmed what i was thinking anyway, just thought i would see if anyone has done it and succeeded ;D
