Looking for sugestion on a basic milk frother
  • Looking for sugestion on a basic milk frother
    I was thinking some kind of plug-in one, not stove top like the Bellman
    not expensive but does the job well to go with my portapresso
    thoughts?
    Re: Looking for sugestion on a basic milk frother
    The type with the spinny-disc at the bottom seems to be the popular sort, Theres a multitude of units around, from the cheap (the aldi Espressi unit is probably the cheapest) to the somewhat overpriced (stuff like the fancy nespresso jobbies)
    as for stand-alone _wand_ type frothers, I think the last stand-alone unit available domestically was the Mr Cuppachino from blackndecker a decade or so ago.. Not sure if youd find too many of them kicking around.
    Theres Commercial ones also, but theyre definitely NOT all that cheap. ;D
      Thanks, and I dont mind low tech. either,
      but I am very fussy and will not compromise quality in the result.
      those Bellman stove top do look good, around $100 range, just hoping there would be an electric one of similar quality.
        If I find a Mr. Cuppa are they any good?
        good enough for micro-foam and art?
          Originally posted by 472969656A040 link=1340960117/3#3 date=1341034549
          If I find a Mr Cuppachino by Black and Decker
          do they work good?
          good enough for micro foam and art?
          Cheers!
          They are absolutely perfect and the worlds best cafes are now using them in banks. Potential WBC competitors train on them and I believe one sold recently on eBay for $5k.
            Sound just the ticket!
            thanks guys!
            just fill em up with filtered water and plug them in, right?
              Um, no. Well short of what you want if you are
                seems to be a difference of opinion here.
                Flynn, then what would you recommend as a stand alone steamer?
                cheers!
                  cjns were entirely tongue in cheek., no difference in opinion. That white tube on the Mr. Cappuccino - looks like a panarello. They produce thick foam, not textured milk. Useless for lattes and latte art.
                  You want an electrical device that steams milk to a quality that enables latte art. It sounds like you really need an espresso machine.
                    So he was having me on?
                    ahhhhh he had me going, just when I located one too!
                    how hard can it be to produce good steam?
                    What about removing the stupid white thing?
                    there should be some kind of rules about giving false information to newbies, I nearly ordered one.
                    I like humor, but I missed it I guess
                    anyway thanks for chiming in and telling it straight.
                      ;D *Whoosh- straight through to the keeper*
                      Absolutely- and also a rule on silly posts where its clearly too good to be true :
                      I would have thought that the $5k 2nd hand suggestion might have alerted you?  :-?
                        I used to own a Gaggia Baby that had one of those. If you removed the panarello part, the steam arm was too short to reach inside the milk.
                        If you want just steamed milk then that device would probably do the job but not to the standard you required.
                          Just goes to prove how we hear what we want to hear.
                          HA!
                          After all it is just a jug with a wand, they are on Gumtree asking $20
                          so much for that Idea,
                          what do you think about the bellman stove tops steamers?
                            Never used one but those who have said it worked well if I remember correctly. Again, not sure if it is to the standard of latte art. But I have steamed milk from the Sorrentina Atomic and produced good textured milk.
                            You wont get proper sweet-tasting microfoam without the right equipment but have a read of this and this
                              I think you are right, might need a old broken Pavonia that just works with the steamer part or something similar.
                              I want to steam with a wand.
                              Still think the black and decker might work if I can modify it without the white thing and a longer pipe
