Hello,
I've recently discovered that while practising my pours that after I start introducing milk into the coffee and integrating it to lift the crema and start to draw, that the surface tends to break away from the furthest end of the cup as I start to level my cup. As a result the drawn pattern will start to pull towards the centre/sideways/wherever. To better picture this, it's like moving the bubbles from the top of your bubble bath to reveal the soapy water below.
I have no problems getting a good shot or microfoam and whenever I introduce the milk I do it from a sufficient height + a steady stream. I have tried:
1) Not tilting the cup that much
2) Introducing the milk from a lower height and more carefully (better success rate but I have no problems with my current technique at a place where I work casually overseas)
3) Using different milk/espresso/jugs/cups
