Texturing Soy milk - Fixed
  • Texturing Soy milk - Fixed
    I have been having problems since I bought my HX Unico Splendor machine, tried 3 different steam tips but still no go. It was very difficult to get it to do a good job on Soy, often ended up like soap suds or just hot milk.
    Read several posts here ie reducing 4 holes to 2 or making your own tip etc. Decided to check the hole size in my preferred 2 hole tip and found it was exactly 1mm. So bought a 1.2mm and a 1.4mm drill and started off drilling the tip out with the 1.2 drill first. Works perfectly excellent steam and plenty of 'go' to turn the thicker Soy Milky regular we use.
    Now I have a 1.4mm drill I will never use. Still at $2 each I think it was a great solution to my problem.
    Hi there. I think you need to be careful not to make it sound like there is something wrong with your Splendor
    No new Splendor has ever been sold in Australia with a 4 hole tip.
    No espresso machine I know of is designed to texture SOY as standard, and there is a VAST difference between the different soy milks available. That is, it is not abnormal to have to experiment with tips or hole sizes to find one that does the best job on the soy milk of your choice.
    That goes for any machine, not just the Splendor.
    Glad you sorted your SOY milk problem
    Hope that helps.
      I've got the Diadema Reale - same basic inners & tip I believe?
      Took a while to adjust technique for soy (Vitasoy Original) but have now got it down to an artform. Need to work it much closer to the surface than milk. Now I struggle to do milk without ending up with Meringue!
      And no tip mods required
      Cheers Matt
        Hope that helps.
        TOK: Don't get me wrong. I had three machines before the Splendor and I am hoping I get buried with it. I never claimed that the 4 hole was the original, don't know where you got that idea.
        Having had an espresso machine for more than 10 years I know there are many differences in soy and I have tried most of them. I have also had to experiment with coffee to stop curdling.
        I appreciate your support for this great machine but it was not necessary. The post was more about 'this is what I did, it might help you' not some attack on my machine.
          Hi Ardy
          A little aside…
          I'm intrigued by this. I have heard some complaining about soy curdling, but I've got a theory (for what its worth ). I've never had soy curdle under heat (and we've tried most soy's too). But the rare time it has happened to me at home (and out and about) has been with lighter roasted, more acidic coffee (like Yirg).
          So maybe the curdling is from the coffee? Is this what your 'coffee experimenting' was referring too?
          Cheers Matt
            Originally posted by DesigningByCoffee View Post
            Hi Ardy
            A little aside…
            Cheers Matt
            Yes Matt I agree. We used to buy beans from a small coffee roaster near us and it was great for about a year then the dreaded curdling started. Tried other blends of his but it seems to really be an acid in the beans.
            We are using a coffee from our local deli and that is working well for us. Bought an expensive, organic coffee from Byron Bay to try, when we were there after Christmas. It turns soy milk into tofu almost immediately. Not that great with milk either, come to that.
              Sounds like their roasting style might have changed. You can increase/decrease the acidity through the profile. That's one of the great things about home roasting - you can adjust the roast to suit your medium. A longer roast can help to richen up the white coffees and stop the curdling, but then black coffees can suffer with a little flatness or increased bitterness. It's the holy grail to find a perfect 'everything' bean & roast! Guess that's why roasting is an art and a science
                Very interesting Matt as the guy claimed that his roast had not changed, but we could never get a decent Soy coffee for my partner from him. However his decaf swiss water was excellent. But I don't want to drink decaf coffee all the time.
                  Drinking decaffeinated coffee is kind of like kissing your sister.
                    I wouldn't know... I've only ever tried the decaf
                      I've never tried decaf!
