Today's Age Epicure Coffee advertorial tripe.
Bugger. My home and commercial machines only produce steam at circa 1.2-1.5 Bar. Where do I get me one of these 15 Bar steamers?
Milk tips for the home barista
mugshot
matt holden
A recent video on Slate.com shows how to make frothed milk at home with nothing more than a mason jar and a microwave (after the microwaving they suggest you put the frothy milk in a cup and add filter coffee). But such a preppy crappuccino wouldn’t cut it in a Melbourne household. And who has mason jars anyway?
Texturing milk is simple if you’re working with a commercial machine that pumps out steam at 15 bars, and even easier for the Victorian latte art champion, Sensory Lab’sBen Morrow. With the machine prepped, Morrow can have the milk ready in 10 or 15 seconds: silky, glossy, slick are the words he uses to describe well-textured milk. ‘‘When you’ve finished steaming it and you move it around in the jug it should still feel malleable,’’ he says. ‘‘When it’s at its peak, it’s hard to tell the foam from the liquid. It’s like whipping meringue.’’ But with domestic machines making steam at only five or six bars, the task is a little harder.
‘‘You can make good texture with any kind of nozzle,’’ says Morrow. ‘‘But if you have low pressure it’s hard. The pressure is too low if it takes more than about a minute to heat the milk.’’ At home, go slow and steady, he says. Start with fresh, full-cream milk, and while cold milk is preferable, using room temperature milk will help get it hot quicker. Just submerge the tip of the steam nozzle in the milk, a little off centre in the jug, with the jug tilted to 45 degrees. Then open the steam valve, and when a vortex forms around the nozzle, lift it slightly. Focus on maintaining the vortex, says Morrow. ‘‘Slowly bring in small amounts of air,’’ he says. ‘‘You want that ‘crisping’ sound in little bursts – otherwise you get bubbles that are too large.’’ The vortex keeps the milk spinning in the jug, which breaks large bubbles down into microfoam. Work until the jug feels just too hot to touch. Aim for a five per cent increase in volume, says Morrow, which will keep the foam integrated in the milk, not separate. Banging the jug on the bench breaks up the larger bubbles, and if you want to work on your latte art, Morrow suggests YouTube – and his Instagram.
mugshot
matt holden
