Power Generation Grid Feed System is the subject
I have ordered a 1 KW solar system with help from the government grant its worked out very helpful price wise
In QLD we have a grid feed set up in which they pay you for the access power you produce (I think thats how it works)
However to be more self sufficient power wise
I have some ideas of a hybrid system
I need to ask some electrical engineers that can think outside the box if this will work
Wind Turbine normal system works by air pushing the blades and turns a power generating motor
I have some thoughts and plans that eliminate the use of the fan blades and the pole
My plan is to use a John Bedinis monopole motor connected by belt & pulley or Direct connection if it suits to turn the 5kw power generating motor that is normally turned by wind power
In this way I can build a system that can run at maximum rated speed 24 hours a day on a very small footprint at ground level
So does anybody know how to build a Bedini Motor or Buy a quality kit
And does my idea have merit ??
This drawing is a rough plan of the components
