Pictures not showing in CS
  • Pictures not showing in CS
    Im using IE6 at work.
    It wasnt a problem when I was here last time but I dont have Admin rights on this PC.
    However Advanced settings = "Show Pictures" selected.
    Another problem (in case its a clue) is when clicking on a username to get to the link to their profile, I get a "Error on Page" message.
    Any clues?
    Re: Pictures not showing in CS
    Any clues?
    Yeah, dont be so nosy. ;D
      Do they have javascript disabled perhaps ?
        I vote for that one too.
        You will also get some BeanBay grief with Javascript disabled.
        Tell your I.T. guys to relax bit, their locking machines down just makes the PCs less usable and wont protect them from real Internet nasties which will get past their feeble rules.
        ...I bet you still have access to USB ports, all sorts of bad stuff comes into businesses via thumbdrives.
          Any clues?
          I have IE6 at work and no probs for me but I have admin rights.
          Could be a policy edit thing but doubt it. Is it the only site affected? Have you tried a google image search? Otherwise, try resetting IE Security level to defaults. Also, see if it works on someone elses PC.
          Something else you might try is right click a picture, copy its URL and then try to open it directly in IE by paseing into the address area.
          Otherwise, get back to work!
            Java is enabled and up to date.
            I actually got a new PC recently because of previous java problems.
            Yes its only CS, I can see pics on other sites and with a google image search.
            Andy I have no control over the IT guys.
            Steve I cant right click and go direct to the url because I cant even see an icon where the pic should be.
              Hmmm...it  sounds like some sort of scripting issue as no other sites are affected.
              Try this image link http://coffeesnobs.com.au/ads/sponsor/coffeesnobs-brown04.jpg
              Otherwise try good ol MS Support. The MSKB article might help, but without admin rights...  :-/
                Yep - but the site uses javascript. Try this experiment at home :
                IE>tools>internet options>security>custom level>scripting>active scripting>disable.
                Then refresh or restart IE and see if you have the problem.
                  That picture I can see.
                  Let me clarify...its only pictures within posts I cant see.
                  I can see banners and avatars.
