help needed to wire 12V relay
  • help needed to wire 12V relay
    excuse my crude drawing......
    my understanding is (and just wanting confirmation)
    0----------------1  is the current to switch the relay
    3-------4 if i wire here it is "on" until current switched it to off
    4-----     -------2  if i wire here its "off" until switched when current at 0----1
    thanks
    Re: help needed to wire 12V relay
    Depends...
    But in effect yes...
    One usualy needs tonknow what the de energised stat is ... Ie. NO. Or NC. Thus you can plan / manage the state in a fail status.. Many forget and it can cause big problems...
    What is the intended use ???
      Originally posted by 06292022350A26292620222A222933470 link=1275113323/1#1 date=1275114003
      Depends...
      One usualy needs to know what the de energised stat is ...  Ie.  NO. Or NC.
      thanks AM
      do you mean by this that you need to no what is happening at 0-----1
      eg if it has current all the time then reverse my understanding
      if it has no current all the time then my understanding is correct
      usage is a 12v timer (omron, preset timer press switch to run X time) triggering a 12v fan
      thanks
        Yes...
        Most units will State NC or NO status as being NOT energised..
        Ignoring your input/assumptions..
        The drawing you provided would be what I expect with NO POWER applied.
        i.e. 3-4 NC
        With power then;
        3 - 4 = open and 4 - 2 should be Closed.
