Cafetto for electric kettle?
  • Cafetto for electric kettle?
    I usually use lemons to clean my stainless steel electric kettle, but as I have a lot of Cafetto on hand...
    Does anyone advise for or against using Cafetto in it?
    Cheers, Peter
    If its espresso cleaner it probably wont do much , if its cafetto restore descaler then go for it. best descaler iv ever used.
      I used to use white vinegar before I got the water filter for the Giotto, haven't had to descale the kettle since
        I don't mind using vinegar (tree is running out of lemons). What sort of quantity, and do you boil it as you do with lemons?
          OK, thanks. It's espresso cleaner.
            I just use citric acid.
