Corretto as an air fryer?
    Originally posted by trentski View Post
    Wonder how the kkto to would go
    That'd be a goer too I reckon...
    Probably just use the original bowl that comes with the TO. In fact, I'm sure I've seen someone make some very nice Sweet Potato Chips with one of these...
  • trentski
    Seen a few people try the air dryer for roasting beans but not the corretto for cooking chips. Wonder how the kkto to would go
  • artman
    Yeah that's what I'm thinking. The temp and airflow might need to be adjusted to suit but that's all the air fryer is essentially.
    I'll give it a go when I get a bread maker and report back.
    Sounds like it should work, if you have a spare pan or two...
  • artman
    started a topic Corretto as an air fryer?
    I was at Hardly Normal the other day and a lady was demonstrating an air frier (made yummy chips) and I wondered if a corretto setup could be used instead with similar results?
    Would be wise not to mix and match beans and fries in the same pan, but the principles appear quite similar.
    Anybody tried this?
