Originally posted by Yelta
View Post
My rooftop solar stats
The dangerous guy, who thinks he knows the one true path, would be just another pathetic nutter if there weren't so many other gullible nutters looking for someone who knows the one true path.
I think what's going to happen at some point, is that it will become mandatory for new installs of grid-connected solar to include a battery.Originally posted by robusto View PostHowever, this proliferation is providing headaches for power suppliers. All that unused electricity being fed into the grid is not under their control, causing irregular voltage. They can turn street transformers up or down somewhat, but in the future it will be an alarming problem with almost catastrophic technical consequences.
The reason for this is that household batteries in conjunction with solar help smooth and stabilise the local grid.
At present, when there's a lot of grid tied household solar capacity in an area, is there's heaps of power being fed into the system when the sun is out, but as soon as clouds come over, all of those houses that were exporting, almost instantaneously switch to importing, causing wild swings in the grid. There is no buffer. Basically all the houses start and stop feeding the grid at virtually the same time.
Batteries address this in a few ways. Firstly, as the day starts, some houses will charge the battery first, then export. This nicely staggers the introduction of feed in power to the grid, and lines up better with the 2pm-8pm peak. Second is when the sunlight levels drop, the battery houses won't start drawing from the grid for many hours.
Running solar + powerwall here and on a time of use energy plan. This means extremely cheap power from 10pm to 7am (12c). Expensive from 2pm-8pm on weekdays, but the battery means most no imports power during this peak period.
It's way too easy for companies to escape their responsibilities by closing up shop and restarting with a cleared slate - if not a clear conscience. I'm of course assuming some of these bastards even have a conscience.
And don't get me started on shonky products with multiple brand names. Sound familiar? 'If you find a competitor's lower price on the same stocked item we will beat it by 10%'. You can of course find the same item elsewhere, only it will have a different colour and brand name.
Ps if I read the contracts (which are just escape loopholes from any possible liability) I probably wouldn't buy anything. You, pretty much, pays your money and takes your chances.
Yup, the biggest scams around here seem to be the seller using lower quality components and selling them at the higher quality prices putting the warranty fully on the manufacturer and sub-contracting out the installation to a sub-standard 3rd party who per the contract is responsible for any warranty issues on the installation side of things. Just like the manufacturer of the cheapo poor quality components who is nowhere to be found when their part fails neither is the installer when their installation starts leaking and falling apart. Meanwhile the seller walks off scot-free with a big wad of cash in their pocket and no legal liability due to the fine print in the contract that the buyer signed but never bothered to read or didn't understand the consequences of if they did. All on top of not doing their due diligence.
In some jurisdictions laws have been put into place making the seller ultimately responsible for all warranty claims. But...the scammers have figured out ways around that as well, typically setting up what is in essence a shell corporation that at the first sign of any problems disappears with a new one taking its place and continuing business sometimes in the same location, with the same employees, and all the old corporations records intact and still in place.
All of this is of course not limited to the solar panel installation industry, it's the same old scam that has been going on forever.
The take-away? Do your due diligence for all levels of people and companies involved in your project, seller, installer, and equipment manufacturer. The bigger the project the deeper you need to dig. And...Read the contract including all the fine print! If you don't understand it bring in someone you trust who can. Yes it can be a lot of work, but you'll thank yourself down the road.
Java "Trust, but verify!" phile
You are very right Glen. The seductiveness of the warranties unfortunately mean nothing when installers are going out of business all the time, irrespective of their size. (Some then reinvent themselves under another name).
Just like every cheap coffee machine boasts it makes "the perfect" espresso, installers boast they use Tier ! panels -- so they must be top of the range, yes?
No, Tier 1 is something Bloomberg made up and applies more like a Moody's credit rating for the manufacturer and has nothing to do with quality of panels. Misleading advertising I reckon.
Leaving shoddy installations aside -- and I suppose you shouldn't--the number one complaint I've read about is premature inverter failure.
Unless you monitor solar output throughout the day (like me--I love it) you won't be aware your supposedly cost-saving system is producing zero output and you've been buying from the grid for the last 3 months. Until you get your bill then check the dud inverter.
Getting the inverter replaced even under warranty could be a time-consuming hassle.
Panels tend to have a very long lifetime. I bought a used, $80, 40 watter to trickle charge my boat battery 25 years ago, and it's still producing near if not full output. It's anything up to 30-35 years old.
But can the same be said for the 260 watts of recently added new Chinese panels?
Yes, it happens. I think that there are few businesses where you have customers thinking that their system will last decades. The panels generally will but isolator boxes can give trouble and inverters may last 10 to 15 years (and can be repaired).Originally posted by WarrenK View PostA word of caution to look at green tech on Whirlpool. Many happy posters with solar but some have found their supplier has crashed by the time the first inverter dies and the expected warranty claim can't be made.
I suggest the status of the supplier is just as important as a good price.
Have fun.
How many businesses really last decades and can be expected to do so?
The end result is people go for panels such as LG that are likely to be around for a long time but then they pay much much more.
Likewise if you pay double the cost for an installation then you are really paying insurance for the long term so I guess you pay your money and make your choices.
Finally changes to government rules and subsidies mean sudden changes can adversely affect installation businesses and force some out of business.
It is complicated. I certainly would look into who your installer is. The minimum warranty on an inverter is 5 years and some offer more.Last edited by wattgn; 6 November 2019, 02:10 PM.
Sounds like my old GPS ...led me down many a garden path. Directing me to make turns into farm gates, into the middle of nowhere, across the Tasman bridge into the wrong side of Hobart... and silly me would obey her command.Originally posted by OCD View PostCome on fellas. This is starting to get out of hand. There is no 'one true path'. Even if you're religious there about 2,000 of them.
Yes, wording matters, and you have made many incorrect assumptions in your wording. Let me help you correct some.Originally posted by theonetruepath View PostWording does indeed matter.
1. You and I don't buy US solar systems so when we compare USD to AUD we simply use the bank rate. They earn USD and they spend USD, they are not penalised by shonky banks exchanging at unfavourable rates. The equivalent AUD is that given by the prevailing bank rate. Likewise when we buy solar systems we earn AUD and spend AUD. There's symmetry here, you can't introduce an asymmetric exchange rate for no good reason.
2. US citizens when buying a solar system with 6kW capacity spend an average of 12550USD. This is around 18000AUD. Sure you can jump through hoops to try and find inaccurate non-official websites or monkey with dodgy exchange rates or try to take away the solar rebates they get, but at the end of the day "wording matters" and US citizens pay the equivalent of an average of 18000AUD not 'over 30000AUD'. 18000AUD is much closer to half of what you said.
3. Why do you keep bringing up what Robusto paid... it's hardly relevant to your claim "The average 6kW system installed in the US costs over $AUD30,000" or my refutation thereof. Wording matters.
First off rather than assume that for some strange unknown reason I haven't got a clue what I'm talking about and ignoring what I say try taking what I say at face value.
Now, taking your post point by point.
1.WRONG. While you may not buy US solar systems I do. Just as while you may not do any foreign currency exchange I and many other people in the US do and all of us are indeed affected by the shonky bank exchange rates.
2.WRONG. Not everyone in the US is a US citizen. Yup, words matter. Additionally, speaking of words matter, read what those sites say. They don't claim that the final cost of a 6kW system is $xx,xxx. They say the price with the tax credit is xx,xxx. That's a VERY big distinction. Plus if you read their 'fine print' you'll see they say that not everyone (Such as myself and many others that I know.) may be eligible and/or be able to collect the tax credit. Most people in the US can not collect the full tax credit. It is not a refund but a credit. It can only reduce your federal tax liability to zero. It can not get you a refund.
The site you choose is no more official than the one I choose. It is not a government site but one owned and operated by a private enterprise, just as the one I linked to is. Yours however only operates in/deals with 35 states while mine deals with all 50. When I choose that site a couple years ago it had the highest rating among the solar sites.
3. Apparently you missed the whole point of my first post. i.e. A comparison of the price in AUS vs the US.
Java "Assume what?" phile
Wording does indeed matter.Originally posted by Javaphile View PostI provided a comparative price that was the same as the price I quoted from Robusto's post:
i.e. the installed price,which was not the price including the tax credit/rebate:
I used the same pricing format as Robusto/the quoted post did.
An Installed Price is not the same thing as a Final Price/Price After Rebate unless the rebate is an instant one given at the time of purchase. Given Robusto's wording it was a fair assumption that the rebate was similar to the Tax Credit in the US which is filed for as part of ones Federal Tax Return in the following year.
Did you not read my 2nd post which you quoted in the above post? I gave you the link to the web site I got my figure from:
Which if you go to and tell it to display the average cost before tax credit for the 6kW system you will see a price of $20,331 which is of course in USD. Using the exchange rate at the time of my posting ($AUD1=$USD0.68824) that converts to $AUS29,540.57. As noted at the bottom of my 2nd post that's the bank rate not the rate you or I get. If you add on those extra points that you and I pay that puts the price over $AUS30,000.
Java "Wording matters" phile
State government subsidies in Australia vary among the 6 states and can be in the form of direct cash to the household (in my case here in Victoria) to interest-free loans or subsidised battery.
In practice, the Federal government subsidy is usually paid to solar installers who then quote an after-subsidy installation price.
I provided a comparative price that was the same as the price I quoted from Robusto's post:Originally posted by theonetruepath View PostYou said "The average 6kW system installed in the US costs over $AUD30,000"
The average price for 6kW which of course includes tax credits is 12.5kUSD. If not everyone gets the credits then that bumps the average up a bit, ie to 12.5k. It's already factored in. That's 18kAUD which is closer to half of "over $AUD30,000"
i.e. the installed price,which was not the price including the tax credit/rebate:Originally posted by robusto View PostCost installed including 5 KW inverter: $4690
I used the same pricing format as Robusto/the quoted post did.Originally posted by robusto View PostLess $2500 rebate $2190.
Did you not read my 2nd post which you quoted in the above post? I gave you the link to the web site I got my figure from:Originally posted by theonetruepath View PostNot sure what web site you can point to that gives a figure over 30 000AUD. The site I gave specifies prices for systems using individual panel manufacturers, only one that I could see charges as much as that for a 6kW system. They charge like champions though, at 30kUSD for a 6kW system.
Which if you go to and tell it to display the average cost before tax credit for the 6kW system you will see a price of $20,331 which is of course in USD. Using the exchange rate at the time of my posting ($AUD1=$USD0.68824) that converts to $AUS29,540.57. As noted at the bottom of my 2nd post that's the bank rate not the rate you or I get. If you add on those extra points that you and I pay that puts the price over $AUS30,000.Originally posted by Javaphile View Post(There are others who state higher average prices such as the one I used.)
Jackster....I presume you don't live in a suburb with neighbours just an arm's length away then
You said "The average 6kW system installed in the US costs over $AUD30,000"Originally posted by Javaphile View PostThat price is after tax credits, which depending on your tax situation you may or may not receive. Per that site the pre-tax credit price is $USD17,940 which at the current exchange rate* is $AUS26,066
If you want to talk after tax credits/rebates Robusto's 6.6kW system w/ 5kW inverter ended up costing him $AUS2,190. Per the site you linked to (There are others who state higher average prices such as the one I used.) the quoted $USD12,588 after tax credits for a 6kW system converts to $AUS18,246, over 800% more than Robusto's cost. So the ratio is showing an even better price for Oz than when comparing the before tax credit/refund prices.
Java "Apples to apples" phile
*Note the exchange rate used is the bank rate which none of us get so the actual price paid would be higher.
