Recently my solis sl-70 has a leaking steamwand. So when it heats up water starts to leak out. The problem is when I start to steam, I turn the knob and steam starts to flow out but very weak stream even when its turned all the way. Now if I press the knob in I get the normal strong steam and when released it goes back to a weak stream of steam. Im suspecting that the washer or something inside the steam valve has started to fall apart.
So the main question is where can I get some parts for this steam valve?? Im pretty sure Diamond C is the importer of these machines but not sure if they are still around?
