Ikon Users !! need help 4 Broken Ikon (no steam?)
  • Ikon Users !! need help 4 Broken Ikon (no steam?)
    need some help
    I have a Ikon i got for nothing and although it heats up it does not make steam.
    it turns on heats up pump runs and fills etc seems hot and looks like it will make a shot but when i press the steam button NO steam (it does not heat up extra hot for steaming)
    steam button seems to do something if i hold it in a long time, goes into some sort of program / clean mode?
    no manual (still looking online) but assume you just press "steam" and wait but nothing happens
    i have the top off it and it all looks OK but no steam??
    any thoughts?
    Maheel
    Re: Ikon Users !! need help 4 Broken Ikon (no steam?)
    Electronic :-)
    Would need to have in my shed and ability to measure / play
    Ya know where I am...
    Cubby is a drop off point if I am not at home...
    Sundays are usually good but have a Function this Sunday and will be attempting to provide 105 guests with coffee
    May have a little time on Saturday... As the weather is putting stop to a few other things...
    AM
      yeah thinking that AM
      might have a bit more of a play of the basics, no rush will give you a shout if no joy
      just thought if it can be coaxed back to life I can pass it on to someone in need etc
      at worst a few more parts in the "parts box" to pay it forward
        Any time..  Problem is if a driver or timing cct is dead or not getting a signal...  Who knows what Easter egg the programmer has embedded for when the steam button is held down.
        We had a habit of embedding Quotes and paragraphs of Tolkin in some of our code that we developed for some medical analysers many years ago.
        Then about 5 years later I was just looking with a hex editor one day, as some stuff was performing same type of function...  Presto.. Not only some of our code and  Quotes but a response or two...
        BOT.
        It could also be a sensor that is causing the system to not respond or another switch that is active and thus the steam and Unknown is then putting the system into the clean mode you mention ?  Just a thought..
        Do you have ausers manual ? Maybe stuck in some other mode and thus the reason some one put it on the footpath  ;D
        No Steam = "Steam Control Dial has not been turned towards ‘MAX’ position"
        PS. Now for some BF1942 ;D
          i had this problem with my refurbished breville unit...
          i sent it back to breville and even their technicians couldnt fix it so they gave me a new machine...
            Originally posted by 4F60696B7C436F606F696B636B607A0E0 link=1286525317/3#3 date=1286527667
            You took the words out of my head...
            Also, to the OP, you need to "prime" your steam wand beforehand because I had the same problem when I first got mine.
            i.e. DONT turn on the steam button, turn your dial to MAX and let water flow until nothing comes out fo the steam wand.
            THEN turn on steam button and turn up dial to MAX to check steam wand is working.
            Otherwise ask Breville  :
            P.S. FYI the dial is on the RIGHT HAND SIDE when facing the machine.
              this machine does not have a steam dial....
              just a button....
              anyway i picked it up free, was told it had the no steam issue. i thought i would pull it apart to see if it was fixable...
              thought a basic issue might be.
              1. button stuffed / moved (dont think this is the issue)
              2. heating element ( dont think so as only 1 and gets heat to brew)
              3. loose something like micro switch etc (dont think so)
              4. loose wire. still need to check
              more serious issues.
              1. stuffed control board....
              2. its stuffed
              if not fixable, it has some parts that someone will want in the future...
              pump, water tank, ghandle.... ete etc
              right now its under the stairs.... got told "dont leave that POS there for the weekend..." lol  but i will drag it back out at a later date
              hahahhhaaa hhaa..............
                See below:
                  yeah but it does not have any wires running to it i mean, no micro switches etc.
                  but i see what you mean now, and i tried bleeding off some water etc then pressing buttons. your idea is a good one and i will try it again.
                  but its not boiling for steam
                    BTW, the bleeding on an Ikon takes about 1-3 mins for priming (all buttons on, steam button not blinking) and 30 secs-1min for steam (after pressing steam button, steam button blinking)
                      thanks Lilmeh
                      will give it a try i was a bit lost in trying to understand what you meant
                      although not confirmed the original owner told me steam had stopped working so i am assuming its got a issue.
                      by steam dial i was thinking like the 6910, where the steam switch is included in the dial, or the other models where you "turn" that dial lookig thing on the front to steam.
                        Originally posted by 39353C313138540 link=1286525317/10#10 date=1286773296
                        thanks Lilmeh
                        DO not give up...
                        But when you do - I want first dibs at teh next stage of resurrection ;D
                          On the Ikon, (after priming), you have to press the steam button so that it blinks and then turn the dial to start heating. Hope this clarifies it up.
                          Good luck!
                            so i went and got it from under the stairs....
                            like before gets hot for shots
                            once you press the steam
                            the steam light blinks but no heat.... wand open or closed etc
                            popped it open and pushed, pulled, tapped and probed but no help
                            back it goes for now
                            AM if your headed to Hawthorne area and want to take it home PM me
                              Could be over that way mid morning etc.. OR about lunchtime... Have a small job at Greenslopes..
                              I will flick ya a PM.. Once I know more.
