Ikon+Nemox Lux Crema Problem
  • #16
    Re: Ikon+Nemox Lux Crema Problem
    Originally posted by 51626D677A5C442D030 link=1286770287/14#14 date=1308114880
    No crema usually means stale coffee.
    I knew I shouldve mentioned the fact that Im using freshly roasted coffee (roasted myself).  Im assuming there is nothing in my roasting practise that could have a massive impact on crema, but could be wrong?
    My "go to" bean of choice is the Peru Deja Silva, and I usually try to let it rest for around a week, and use within a total of 3 weeks from roast date, but sometimes due to poor management of my stock levels, use prior to 1 week, or post 3 weeks where needed.
    I must admit that I generally store the roasted beans in ziplock bags, which is not ideal.  They are stored in the bottom of pantry inside a supermarket cooler bag to try to control heat, light and humidity.  Any potential impact from this storage method?
    • #17
      Gday Damien...
      Nothing particularly wrong with that storage method if youre talking small bean quantities that you consume in a few days... Longer periods than this you should be storing in 1-Way Valve Bags...
      The presence or lack thereof of Crema could be down to your technique, i.e. your Dose, Distribution and to a lesser extent, your Tamper and the consistency of the force you use. Perhaps you could make a video of your typical routine and then we can take it from there....
      Re: your home-roasting method... If the coffee in the cup tastes great then theres nothing wrong with your roasting method.... 8-)
      • #18
        Others may comment and may think differently, but I use ziplock bags and have no problems with this method. One way valves are not necessary for small amounts of beans. If you are roasting 1kg at a time, the degassing might cause probs, but I currently do 150g batches. I dont worry about light or heat once I crack open a bag as it only lasts a few days. YMMV
        • #19
          To the OP, I figured out the problem but I havent fixed it yet.
          Im pretty sure its the tamp. I also adjusted to finer settings and now its ok but not brilliant. Until I have money for a Pullman, its going to take awhile to fix
          • #20
            Taken me a while to get this organsed - finally got a (large) shot glass and made the time to check out what was going on, plus take some video.... not sure what I was worried about (in terms of crema) after all that.
            http://www.youtube.com/watch?v=HeUgSixgtvI
            • #21
              P.S. I forgot to mention to some extent, the problem was the width of my mug heh.
              • #22
                That shot looked pretty decent to me Damien 8-)... Maybe a little longer than I would go for but thats just down to personal taste....
                • #23
                  Thanks Mal.
                  Youre probably right... to be honest I was so focussed on the volume of the shot (watching the 60ml line), not to mention concentrating on holding the camera in the right spot, that I probably threw my normal processes out the window a little... in fact I even had to watch the video back afterwards because I realised I hadnt even been paying attention to blonding etc!
