Breville Cafe Roma - problem fitting group seal
  • soviet
    Re: Breville Cafe Roma - problem fitting group seal
    Yes he would have as I have just done the same thing with a Breville Roma and is does the same thing. I think the problem is the point of exit is above the seal and not that the point of contact between the filler basket and rubber. Will try some a fine amount of high temperature silicone gasket sealant, thought not too much. Let that set for about a day.
  • Hatchy
    Did you ensure to install the seal the right way around, and with the shower screen also in the right order?
    Another CSer used silicone.... up to you.
  • coffeelust
    started a topic Breville Cafe Roma - problem fitting group seal
    I just replaced the group seal on my parents machine and now cant get it to work properly. It starts the shot OK but then makes a loud popping sound as it finds a weakness in the seal somewhere and water starts spurting out around the sides of the group handle. Anybody had a similar problem? is it fixable?
    L
