Unpressurised basket????
  • Unpressurised basket????
    Ok I have a sunbeam cafe crema and im pretty sure it has a pressurised basket as it only has one little pin hole on the bottom. (you cant see out of all the holes). Does anyone know if a Krups unpressurised basket would fit into the portar filter?? if so would it make that mush of a difference as i have heard that the krups unpressurised basket produces little or no crema and the basket easily falls out in the knock box?
    Can anyone help.....
    Re: Unpressurised basket????
    Im using a Krups basket with the cafe crema. I had to attack the spring in the holder with a pair of pliers to make it stay in when you knock out the puck. But with freshly roasted, freshly ground coffee it produces plenty of crema and you can get a proper slow extraction. If you use stale coffee, or have it too coarsely ground, no
    Crema.
    Theres a bit of a fine line with the machine between having it choke up completely and producing really quite decent coffee. But if you can dial that in on the grinder for a cheap machine it does OK.
      ok thanks. so you recommend getting one?
        Susan where did you get the unpressurised basket?
          Order the ones from breville. Exactly the same size, but unpressurised.
            I presume these will also work with the EM3800 Cafe Espresso?
              To answer my own question....Yes the Breville BSWF100 baskets fits the Sunbeam EM3800 perfectly as well
