Hot Milk Equipment
  • Hot Milk Equipment
    Hello ladies & gents,
    Im looking for the best equipment to heat milk (just milk with spices or Chai) with the following criteria:
    1) heats the milk or chai to a high temperature (above 90 deg C as high as possible without burning..)
    2) long lasting, sturdy construction.
    3) easy to clean.
    4) can be electric or stovetop.
    5) faster is better!
    6) reasonable pricing (below 150$) for personal use.
    i dont know if coffee makers / steamers /equipment can be used for this purpose, but please let me know of any solutions, types, brands, models, or any other ideas that can help
    much appreciated!
    Re: Hot Milk Equipment
    Unfortunately, I dont have any suggestions for you,
    but I would just like to recommend that you dont take the milk up to 90 degrees, the smell of burnt milk is repulsive!
      well im hoping that with a steamer solution it wont burn, but im no expert.
        I dont think that a steamer solution will make much of a difference, the burning of milk happens when the temperature exceeds about 70 degrees, causing the denaturation of proteins within the milk.
          Lets make yoghurt.
            will it work if i put milk in this? :
            http://www.amazon.com/Bialetti-Express-12-Cup-Stovetop-Espresso/dp/B000FDL588/ref=pd_rhf_p_t_3
              I dont know why you would bother. You will get the same result with a saucepan.
                Originally posted by 49686363647E0D0 link=1313381706/6#6 date=1313396209
                saucepan.
                Bye Jove I think Den has got it!
                  alternatively you could get a soup kettle like cafes use to keep soup hot but I dont know what this would do to the milk.
                    You could try the Bellman stovetop...not sure if it will come under 150 dollars but it wouldnt be much over.
                    Or...just use a microwave.
                      My beard turned grey with age. What happened to yours? Accident with a blu loo, maybe
                      G.
