EM2300 gushing, and/or blocking up!
  • jameslol
    Re: EM2300 gushing, and/or blocking up!
    argh! ok so i have been using the single shot thingo. all this talk of updosing made me try the large basket again. i dosed it up huge and tamped real hard, and i got probably a bit more than 15 seconds on the extraction! thats some results. it was, umm, acceptable. add some nicely steamed milk and it wasnt a bad coffee!
    now ive had a couple too many coffees today bzzzzzzzzzzzzzzz
    thanks for help guys
    using padre beans by the way. yums
  • LaughingAtFate
    Hmmm, What beans are you using? how old are they? etc (Ive had the same sort of problem with my EM3600 with homecut single walls) Ive found that if I updose on the larger grind and tamp heavilly, it seems to work quite well.
    I would suggest getting a different tamper... the plastic rubbishy thing is only really useful as a bean-scoop Ive found
  • jameslol
    thanks for the reply
    the dose is already pretty high though... i fill the basket, tap, put more in, smooth and tamp (30 lbs)
  • dr.a.j.pickering
    Originally posted by 7B707C74627D7E7D110 link=1315277141/0#0 date=1315277141
    is this simply a limitation of the el cheapo machine? does it not have have enough pressure?
    more likely a limit of el cheapo grinder
    sound like you need to grind on 9 and up dose and tamp heavy
  • jameslol
    started a topic EM2300 gushing, and/or blocking up!
    hey folks!
    long time listener first time poster...
    i have an em2300 (sunbeam cafe ristretto) with the breville single wall filter set. and a conical burr em0450.
    if i grind at a setting of 9, my machine gushes pretty bad. about 10 seconds for 25 ml. bit of a watery taste there
    if i grind at a setting of 8, my machine blocks up and cracks the shits, almost every time. sometimes it sort of works, but its a gamble.
    the other "weak link" in my setup, from what i can gather from these forums is that i use the plastic tamper still... but im not sure if i can see a connection to the issue im having.
    is there something im missing?
    ive tired heaps of different tamping (on scales as well) which seems to not really change anything.
    thanks!
    james
