Re: Easy to use machine less than $500?
Hey Al cap
Just a thought
Have you considered a stove top unit like the one at La Sorentina (site sponsor)
Looks to be a nice easy machine for Mum plus has some bling 8-)
http://sorrentinacoffee.com/
If my mum gets totally better she might consider ripping the guts out of the VV PF to go unpressurised...
Can vouch for the Saeco VV also, ours is 6 years onld & has been quite reliable.
Good luck...............cheers................Sean
All good advice, thanks for that
I agree with Speleomikes suggestion of checking out her taste tolerance to identify the best approach. I think we CSers think what is best for ourselves is best for others which leads to our ultimate dissapointment. Most people are more into the ritual of coffee drinking, eg pausing for a rest, sitting with friends, making the effort for friends, the smell of coffee beans in the room etc rather than the taste. Regrettable but true.
Another vote for the Saeco Via Venizia. Makes a respectable coffee and easy to use (no tamp required).
I will stand by the fresh beans, good grinder, & VV as long as it works for your mum. IMHO, the VV is better than others at these price points and will outlast them as well. If you go this way, itd be good to clean it out once in a while by unscrewing the portafilter and brushing off the buildup around the plastic mechanism.Originally posted by Al_Cappuccino link=1214209650/0#10 date=1214364135Mums staying this weekend so I might test her out (supervised) on my gear. CS condemns the pod and pretty much all the Superautos as well so I reckon if she can get used to a VV and a stepped grinder (Ill order her beans from Bean Bay on a regular basis, any auto top up options on BB?) she will be happy.
Just one more point, is the VV so much better than the cheaper Sunbeams, Brevilles etc??
I would recommend a Gaggia which combines the advantages of cost and simplicity. A good entry level machine
The Baby Class is manual and operates like the Silvia. There is also a Baby Doser (slightly more expensive) which will stop when the required shot is poured. The Baby Twin has twin boilers so you can steam at the same time as pouring a shot. I think the Gaggia Classic is similar to the Baby Class.
Some tamping technique is required and you dont want to use the plastic ones that come with the Gaggia. To avoid the need for a grinder then try the coffee pod. I have tried pods that I bought for my previous machine (to encourage my wife to make her own coffee) and these are adequate as long as you dont need a good crema. Well I have never achieved a good crema as you cant control the tamp.
The Gaggia Baby comes with a single basket designed for coffee pods and I assume other Gaggia models have this too. I have bought coffee pods from www.coffeedirect.com.au but you can also but the Illya brand in DJs
Hi Al
I think when it comes to a 65 year old with any disability it would be good to test here out with her how she uses a machine and what here tastes are like. As you said, youll test here out this weekend - good idea. Suggestions here ranged from Nespresso to manual machines like a Silvia. That ranges from hassle free to possibly too complicated.
After you have tried here on your machine this w/end I would suggest to see see if a place nearby can demo a pod based coffee machine to you in their shop. Take here along and see if she likes the coffee from it. If its fine for her and she likes it get that. Far less hassle and mess.
(suggestions above based on getting a PC for my mum at 75 that has never even used a keyboard before)
Mike
Hi Jason, I agree with sd, the Via Venezia is a good little machine, has a stainless boiler and makes an ok coffee. Sounds like your mum wants simplicity of use and VV could be the answer. I started out on this machine and I was quite happy with the brew until I joined Coffeesnobs and the upgrade bug hit me.
A pressurized porta-filter will also cover a multitude of sins in terms of grind and tamp. The saeco via venezia is under your price range (400-450) and if you use it off the shelf, its designed not to need much tamp pressure at all.
The coffee will of course not be the best, but fresh beans and a good grinder will help in that regard.
all the best,
sd
I thought about a Nespresso system too. She is recovering fairly well and probably be up to loading and using a grinder but she is not so good on managing complex tasks and things that require some heft such as wrenching on a PF, hard tamping and so on. She may find a Nespresso provides a reasonable output compared to a poorly used machine (not to mention potential danger of not putting the PF on properly etc).
There are some pretty fancy auto machines out there but are almost the same price as a small car! She probably has enough money to get one but I cant imagine the service costs associated with them. Does anyone on CS have any experience with the auto systems. Are they worth it compared to the pod systems??
Just as background, she loves espresso coffee (with frothy milk) but is going to be much more home bound these days so access to good coffee might improve her quality of life somewhat.
Hi Jason,Originally posted by Al_Cappuccino link=1214209650/0#5 date=1214294921THanks for the advice 2mcm, I thought about the Silvia but it looks to be a gear freaks tinkerer machine thats tricky to get right, great for me but not for my 65yo mum who is just getting over a stroke (ps not a coffee related problem).
The original question was something that was easy to use and reliable, and doesnt necessarily need the grind just right and the tamp just right but will do a pretty good job (ie bit of a wide range) under variable conditions including output from a stepped grinder. Not so much a connsumate CS machine, but at least a machine that wont upset me greatly when I come to stay with her.
I dont want her to go into DJs and be duped into buying a gazillion dollar Krups with all the bells and whistles that requires more servicing than a Ferrari and results in a pot of Nescafe beside her machine...
Jason
I dont believe I am saying this, but at 65 and after a stroke, I dont think Gaggia or Silvia will be suitable as they very much similar in operation. I think Id actually have to suggest something like a Nespresso type system . I think a grinder and having to load etc will possibly prove too challenging. Alternately, perhaps some type of Superauto...
Jason
Id suggest a 2nd hand Rancilio Silvia,
Pre-loved CS member machines appear here relatively frequently as upgraditis hits. A Silvia will do the job well.
In addition, the boiler is brass rather than Aluminium and this will lead to a longer lived machine which can later be upgraded with a PID should your buddy become more retentive
