My Knob is STIFF need help
  • My Knob is STIFF need help
    ;D On my Via Venezia that is !!!
    When I turn the steam knob its very tight.
    History: 4 years old, on every day, steam button has been left on a few times,
    never been serviced however has been cleaned.
    Shane
    Re: My Knob is STIFF need help
    hi hornet
    the staem valve in the via venezia is brass
    if these are not lubricated they become stiff
    if they become stiff, and continue to be used
    it damages the thread
    sometimes the shaft needs replacing other times complete valve
    needs serviocing
    graham
      I thought I was on the wrong forum when I saw that subject
        Me too!!!
          Hi Graham,
          How do I lube it up.....so to speak.
          Lizard,
          So what forums do you usually visit ??
          Shane
            you pull it
            apart
              Couple of tips dont use KY Jelly for lube (its water soluble) Vaselline tastes bad so try your local bearing shop for Food grade grease or lube
              If that fails seek out the services of a Professional to make you knob less stiff
                All I can say is that, Im completely disappointed...
                  In recent communications I have discovered that Urnex is using Viagra as an anti-foaming agent in their espresso machine cleaner. If you have recently cleaned your machine it could explain how the knob became stiff. If the stiffness lasts more than four hours you are advised to consult your nearest appliance repair centre.
                    Has anyone actually done a service (Lube) on this machine?
                    Ive taken it apart (steam knob handle was interesting) but not sure where to put the lube?
                    Shane
                      Oh you actually wanted a serious reply
                      If it is like most valve assemblies then the area that needs lubrication is the valve stem where it goes past the gland and packing. Do not lubricate the valve face where it seals.
                      The pic is just for reference and placing a name to the bits.
                        I have to congrat all respondents for one of the funniest threads I have read in many a long day.
                          Id say let a professional service your machine thoroughly with lubricant to rub out any stiffness. It should blow very well after a good servicing (steam that is).
                            hi shane
                            when you dismantle the steam valve you will have a brass spindle (or valve stem as per previuos pic) with a thread on it. this is where the it needs lubing
                            we use a high temp food grade grease
                            if the thread is damaged, then a new shaft needs to be fitted
                            graham
                              If you are still having problems then try Spoilers Relaxation Centre in Ringwood for your nearest professionals
