Help with Ikon BES400 and EM0480 please?
  • #16
    Re: Help with Ikon BES400 and EM0480 please?
    Thanks. That works when making a single coffee. I guess the problem is when making multiple coffees in a row for a bunch of people.
    • #17
      Now youre talking an upgrade to Hx. ;D
      • #18
        Ive got an Ikon, and also remove the handle last thing when cleaning down, luckily im usually only making one as the Mrs doesnt drink much coffee, even more so at them moment as shes pregnant so off any caffeine.
        But youre right i think this is the only way round it which is a bit of a pain if you want to make multiple coffees, one way round it is to make one at at time, by the time youve done your milk you will be able to remove it..
        • #19
          Thanks guys. Im not sure what an "Hx" is. I have found that if I turn the handle a little to let a small amount of pressure off, then do the milk, the handle can be carefully removed without too much mess.
          • #20
            Hx=Heat Exchanger, or a mid to high level machine that has a pressure relief valve. Some single boiler, dual purpose machines have this as well. The base price would be in the area of $1000 and then "up, up, and away!"
            • #21
              Thanks for that. So this is par for the course with any Breville or Sunbeam home unit?
              • #22
                If you are making multiple coffees for "a bunch of people" the Ikon is not really the tool for the job (unless you plan on spending most of the night at the machine), it is great for one or two coffees at a time, but beyond that, and you are pushing the boundaries.
                Have you tried any of the other Chch suppliers?
                With your Ikon, convert your group handle to bottomless (push out the eject button). This will leave a big gaping hole in the bottom of it, and mean you can only do 1 coffee at a time, but there is a marked improvement in the taste of the shots when this is done (even cleaningg the button thoroughly still taints the espresso shot).
                The "coffee sneeze" is common amongst any units without a release valve (one way valve?), if you are releiving the pressure a bit, then steaming, then removing the handle without too much fuss, sounds like its as good as you will get. I get the coffee sneeze sometimes, but not others (usually if I have over extracted the coffee and its poured a little slow).
                Are you still using the "tamp" that is on the end of the scoop that came with the Ikon? Splash out and get a proper one if you are. There is a a sunbean "barista kit" sold at Harvey Norman that has a small tamp included, this is what I use at the shop and it is a near perfect fit. You wont get any sort of tamp pressure with the Breville scoop thingy
                Sen
                • #23
                  Hi Senator.
                  Thanks for that info. I only make one coffee at a time using the double-basket, 35-40ml shots over about 25 seconds into a 150ml cup.
                  I bought a tamper from C4 not too long ago. The plastic thingee wasnt really usable. Today I bought 500gms of Vivace Ultimate Espresso beans from their shop. Will see how they go.
                  Thanks.
                  grol
