unpressurised double basket for Breville 800ES
  • unpressurised double basket for Breville 800ES
    Hi All
    Anyone know where I can get one of the above baskets in New Zealand?
    Andrew
    Re: unpressurised double basket for Breville 800ES
    Try your local kitchen appliance repair shop.
      didnt think of that - thanks.
        I believe most people use the Krups baskets. If you do a search you can find the part numbers in previous threads.
        As rival suggested, try contacting an appliance repair store, one that specifically services Krups machines. If they dont have them in stock they should be able to order in for you.
        Good luck
          Tracked down a local applicance repair shop who are Krups service agents.   Basket ordered.  thanks for the suggestion.
          for reference - any Kiwis who might need the store was Kings radio in Hamilton - website http://www.kingsradio.co.nz/index.php
          cheers
          Andrew
            Wow! A musical basket.
              hopefully will get some improved notes from my coffee
                Hi, first time poster and new espresso amateur.
                Got the Breville 800 and as many, I want to fit a non-pressurized basket.
                I checked the Breville BES860XL and it seems to come with both type of baskets, single and dual wall.
                I did some research here and there and did not found anything about fitting the unpressurized basket from the 860 on the 800.
                Maybe its simply not the same size.
                  Correct.
                  Welcome to Coffere Snobs.
                  Youll need to get the hang of searching.
                  Heres one that mentions new unpressurised baskets for the 800:
                  http://coffeesnobs.com.au/YaBB.pl?num=1237642712/34#34
                  This one appears to mention a part number:
                  http://coffeesnobs.com.au/YaBB.pl?num=1188083851/18#18
                  And another:
                  http://coffeesnobs.com.au/YaBB.pl?num=1228563735/4#4
                    I believe the 800 and 860 may not be compatible sizes.
                      Didnt I already confirm that?
                      Correct.
                      Yes I did.
                        Thanks Thundergod, I asked Shawty if he/she have an update on this unpressurized Breville basket.
                        Ill contact Breville also.
                          Ill save you the email.
                          Theyll tell you to try the basket from the ESP4 (with no guarantees that itll fit).
                          Save the time and find yourself the Krups basket.
                            just had a call back from the place in hamilton I ordered this from - out of stock in NZ and around 6 weeks delivery.
                            canceled the order..
                              canceled the order..Sad
                              One of our site sponsors, Pullman Espresso, have them.
                              Youll be paying a bit more for shipping to NZ but youll have it within a week.
                              BTW I got mine from Greg earlier in the week so hes definitely got them in stock.
