Breville 800ES + BGC450 + mod = good coffee
  • Breville 800ES + BGC450 + mod = good coffee
    After a lot of reading on CS about the B800ES, I decided to take the plunge and accept one for fathers day.  Mrs willyroo snaffled one with the grinder from GG Mt Gravatt for $288 :0 .
    I bought a bag of Di Bella coffee from Espresso Lab in Annerley - good coffee (and coffee shop) btw.
    First brew - an OK coffee.  Plenty of experimentation, always just OK to sometimes good.  So back to CS, more reading, and a vague mention of a Krups basket.
    Next steps - contact the great team @ Pullman Tampers for a Krups unpressurised basket, and a strong recommendation for a tamper as well.  That was the key...Krups basket + good tamp.
    The BGC450 needs to be set at the finest grind setting (Turkish), and you need a very good tamper to make a quite firm tamp when using an unpressurised basket.
    Oh and I bought a decent frothing jug.
    The key to good coffee with this combo is:
    This combo gives a good 25 second extraction, and a shot to rival many coffee shops.
    Cons:
    The 800ES is hard to master frothing - however you do get it in the end.  Need to start steaming in a separate cup until the water runs through and converts to steam.
    The BGC450 is a b@st@rd to clean!!
    So if you are thinking about the 800ES, you can get good to very good coffee with care and the right - simple - modifications.
    Re: Breville 800ES + BGC450 + mod = good coffee
    25 seconds? Wow I didnt know anyone got 25s on an unmodified BCG450...
    same as the other Brevilles.
    yep! I take out the top burr, use a brush to loosen the grinds, then tip the whole thing upside down and tap it over the sink.[/QUOTE]
    I personally wouldnt recommend the BCG450 now that the smart grinder is out, and so cheap!
    PS welcome to the snobbery
      Thank you for the welcome...
      It is a slippery slope I know
        Ive also got this combo but still cant get any longer an extraction, with unpressurized basket and modded grinder. Am I missing something?
          Have you modified the BCG450?
          If not, theres the problem.
            Modded grinder, yes. Clip removed so it can grind finer and an o ring to keep the top burr steady.
              Just incase anyone is reading this, you need to take out the "second stop" as well.
