Breville Ikon DOWN! Help!
  • #16
    Re: Breville Ikon DOWN! Help!
    my 2nd hand one crash as well.
    I will contact with the seller about this problem.
    It has not even been used, I just plug in and turn it on, it die.
    And idea how to open it?
    I unscrew the 3 star shape behind the machine and 3 under it, the cover is still stay strong.
    • #17
      Hi there,
      I had the same issue about the steam not going. The light flashes and nothing happens. The shots seem to be working ok.
      I pulled the whole machine apart today and found some very neat cabling and electronics. I understand a little about these things, having done an electronics engineering degree... However, that doesnt guarantee anything since youd normally still need the service manual or schematic.
      Anyways, I had a look at the logic board and found that the most suspicious element is the RELAY. I did a quick search on the net and found a replacement part SRUDH-SS-124D1 which is not exactly the same one but I reckon it could work as fine. Im just about to order the part from x-on although it really annoys me that the part costs $3 and they charge $16 for postage...
      Ill let you know how goes once I sold the relay in place of the original one. Not sure this will fix it. It could be many things. It could be diodes or even the processor... Wish me luck.
      Miguel
      • #18
        Breville IKON Not makeing Coffee but will steam
        Its happened before, and after frantically pressing buttons, I got it working but today, nope still not working.
        I think it is time to buy a Silvia!
        Anyone know how to fix this tho? I need coffee now, and the Silvia wont happen till someone in Adel has one to sell ;-)
        Basially the loud noise it makes when the water goes throught the group, goes away, but when I open the steam wand, the noise is opperating like normal.
        Please I need a coffee!!!
        • #19
          Ive had exactly the same issue over the last week!
          With me, if I turn it off - 3 or 4 times sometimes, then it comes good!
          (After running the primer, or running water through normally sometimes!)
          It seems to be an electrical issue to me, as when it does work, it is perfect....
          Its like something is not switching on.
          Did anyone here send the machine in for service and find out a definitive problem ?
          TIA, Dave
          • #20
            Guys, sorry if I sound like one of those IT support guys that only knows how to tell customers to turn things on and off but have you guys cleaned out the insides of your steam wand with the provided pin?
            Its just that (touch wood) I never had any problems with my Ikon but I follow the cleaning instructions to the boot.
            i.e. clean machine (flush and wipe down shower head and steam wand) after every use, dismantle shower head and clean weekly, clean insides of steam wand and flush out with clean water weekly, etc.
            • #21
              <quote>Guys, sorry if I sound like one of those IT support guys that only knows how to tell customers to turn things on and off but have you guys cleaned out the insides of your steam wand with the provided pin?</quote>
              Nah, if you were in front of my machine you would immediately see that this is not the issue - one minute it is working perfectly the next it is like the steam wand is simply not opened up !
              Cheers, Dave
              • #22
                Hi,
                If you cannot fix it would you be interested in selling the steam dial to me, mine threaded the other day and I cannot tighten it enough to stop the steam escaping.
                Brett
                • #23
                  Hi everyone,
                  Miguel, did you get your Ikon going again with the part you bought? Ive had the exact same problem. The light keeps flashing but nothing happens. Ive looked after it from day one (about 2 years ago) always priming after steaming,cleaning the wand etc.
                  Also has anyone found out how much to fix by Breville?
