Cafe Roma single walled basket - leaky and soupy.
  • Cafe Roma single walled basket - leaky and soupy.
    I have finally managed to get a single wall filter for the Cafe Roma and I am using the same grind, dose and tamp as I use in the standard double-wall filter. When I make the shot, coffee dribbles out for a couple of seconds and then it backs up and spills over the sides. I have taken video, please have a look and tell me what you think.
    My thoughts are that the group head does not seal properly against this new basket, already it feels easier to lock in than normal.
    Sorry about the shaky cam, I had to hold the phone with one hand and turn the machine off etc with the other
    http://www.youtube.com/watch?v=Afj9i6dcRds
    Thanks for taking the time to have a look!
    P.S. I dont think the grinds are too fine because I dont have this problem at all with the double filter - and I always end up with a nice dry puck each time.
    Re: Cafe Roma single walled basket - leaky and soupy.
    IMO the grind is too coarse and the coffee is flowing faster from the basket than the holes in the portafilter can handle. Hence the overflowing is around the outside of the basket.
    I have the same issue with my old La San Marco Domus when I grind too coarse.
      So maybe its time to start applying the shims supplied by Breville.
        I got my single wall double basket from site sponsor Uro Coffee and it fits in both the old Sunbeam EM2300 and the new (used) Breville 800ES.  Both machines have a 51mm PF.
        No leaks.
        I have been playing with the grind for the 800ES and yesterday managed to choke the machine with too fine a grind (I have a Sunbeam EM0480).
        I still think you need a thicker seal (or thicker lipped filter basket).
          To hazard a guess, theres a couple of things causing your issues, Id say that one of them is that Youre grinding too course, the other is. When was the last time you checked/replaced your group head seal? Because that might explain the spilling out over the sides. Do you get the leaking from the top with the double-wall filter?
            No leaking with double wall filter, and I really highly doubt that the seal is leaking, I have probably made less than 100 shots with this machine so far. I think the ridge on the single wall filter being too small is far more likely to be the reason... still, I will look at installing my shims next weekend and see what difference that makes.
              Hmmm, Odd, I have heard that the Krupps filter basket is slightly flatter around the seal then the Sunbeam/Breville ones. Are you using a Krupps single-wall, a Breville single wall, or a self-made one?
              Perhaps looking for a thicker group head seal might work on the leaking out the top problem
                I think Breville did supply me with the Krups basket - it would explain those problems. I dont have the leaking out the top problem when I used the Breville-supplied one. With the Double-walled basket I have drilled a 2.5mm hole in the bottom to un-pressurise it a bit an this together with using the new grinder has improved my coffee enormously but I am still sometimes getting a wet puck. Do I need to buy a coffee tamper? All I have is that silly plastic thing that came with the machine.
                  I think the double baskets tend to leave you with a wet puck unless you let it dry out for ages in the machine, at least thats what I used to find with the dual wall double basket and my EM2300.
                  With the Krups (or Krups lookalike), the puck is always dry and knocks out beautifully. I have found this with both the EM2300 and the Breville 800ES.
                  I just received the Breville single wall baskets yesterday and tried them out the double shot last night and this morning and it left a dampish puck.  These baskets are straight walled as opposed to the tapered wall of the Krups and the hole diameter in the Breville is smaller so Im assumming the puck will take longer to dry out. The Breville basket holds more coffee but Im still trying to find the right grinder setting as my pour is still a bit quick and underextracted.
                  A tamper may help, it may also hinder until you get used to using it. The black plastic scoop/tamper is not ideal but better than nothing.  I have a convex 49mm stainless tamper thats just a bit too small so I ordered a 51.5mm flat tamper from site sponsor Sorrentina coffee, I have no idea if the flat tamper as opposed to curved tamper will make a difference but after precisely measuring the baskets I think (hope) it will give me a more even tamp as my pours are a bit uneven at times.
                  http://sorrentinacoffee.myshopify.com/products/la-sorrentina-tamper-51-5mm-universal-52mm
                  Its a journey...
                    Thanks... I feel a bit overwhelmed and VERY confused. Whilst happy with most of my shots they are all so inconsistent and some are so soggy its not funny.
                    Some are getting blocked altogether, does this mean Im tamping too hard or not hard enough? I dont think its the grind because normally the grind is ok. All I did was change beans not the grind size. When it comes to a consistent dose, does that mean I have to make 2 shots even if I just want 1 cup? sooo confused!
                      Different beans = need for different grind size.
                      All beans are different and will require adjustments to grind size as you change bean. As beans age you may also find you need to adjust the grind accordingly too.
                        agh! so... many... variables!
                          I find with my little roma that when i grind too fine and overdose, it will start to leak over the seal (or occasionally blow the handle off). My machine is virtually brand new and the rubber is in good condition. I think these machines are really just built to a very low price and thats what you get. The best shots i can get out of the roma are the slowest pours, however these seems to be a fine line between success and failure. I would suggest trying a courser grind. If its pouring too quickly, gradually grind finer with the same dose.
                            I think i need a new coffee machine. but i dont have a big budget. what should i look for second hand?
                              as long as youre not making many milky cups at one time the answer here is a Silvia or Lelit. Around $500 for something 2 years old - they will hold that value well.
                              Do you have $500? What grinder do you have? (apologies if I missed it above) You may need to fork out more there too to get the best from these more capable machines... youre okay if its a smart grinder
