Just bought a used Saeco Via Venezia
  • Just bought a used Saeco Via Venezia
    Im not sure if Ive made the right decision but I jumped onto evilbay a couple of days ago and bought myself a used Saeco VV.
    Now Im praying that when I pick it up and bring it home it is still in a reasonable condition.
    Can anyone give me some tips on prepping this machine and checking for any obvious faults?
    The only tips I have come across so far are just the usual give it a good clean and descale. Is that all I need to do?
    BTW, I recently bought a Breville BCG800 grinder and have read up on unpressurising the PF
    Last question - where can I purchase a reasonably priced tamper?
    Appreciate all the help I can get
    Re: Just bought a used Saeco Via Venezia
    I must he the 1000th newbie to ask the same questions over and over. Forgive me as Im a total newbie to espresso machines.
    What Ive done so far:
    - Given the machine a good scrub and descaled with a solution made from 1 litre of water and half a cup of CLR
    - Unpressurised the portafilter
    - Flushed fresh water through the steam wand and brew head to rinse off descaling solution
    - Removed outer sleeve of steam wand leaving just the inner plastic sleeve with needle point hole
    - Opened up the machine cover and removed/washed the tube that the pump uses to draws water from the reservior
    - Tried to remove the other tube (which looks like is used to flow back from the pumped into the reservior) but had to stop because it felt like it might snap off. There was a bit of residue in this tube that I was unable to clean
    - To prevent channeling I gave the screw in the brew head a half turn to loosen it up
    This is what Ive tried to produced using the machine:
    - went through a few cups of milk with the frother but only managed to warm the milk with a thin layer of bubbles on top
    - Made 6-8 bad double shots of espresso
    One of the issues I am having is not knowing how much steam the wand is supposed to produce. From memory when turning on the nozzle it starts sputtering for the first few seconds then produces visible steam which lasts for 5-10 seconds. Then I get barely visible steam which lasts for about 20-30 seconds until the boiler light turns off.
    As for the espresso making part. I ground my supermarket bean (practice bean) on the finest setting but no shot flowed out due to clogging up. I adjusted the grind up a notch at a time and got a shot to flow out at the 5th notch. I believe I might have skipped the 4th. At the moment Im producing a bitter, bland and watery shot. I believe Im getting a 60 ml shot to pour in about 15-20 seconds. Way too short.
    Im going to pick up a tamper tomorrow. Will this make any difference to the supermarket bean (Harris Colombian) with best before date July 2012?  Is it possible to know the roast date from the best before date?
    I have a local roaster where I live west of Melbourne. Theyre not thqt well known but I might pick up some freshly roasted bean there.
    Am I allowed to mention the name of roaster and/or parts supply shops on these forums.
    Also, do I need to worry about cleaning the last tube that I couldnt remove?
    Forgive me for the extremely long post.
      A tamper is absolutely essential in getting anything half decent out of any machine.
      Roasting dates on store bought coffee usually allow for a 1 year best before date from roasting date. So a July 2012 date usually indicates a roasting date of July this year, although I have seen certain br ands that have stretched the best before date to two years.
      Use cheap store bought beans to get a feel for things and get the machine producing acceptable shots with decent crema and taste. Once you have achieved this, use a quality fresh roast to make a decent coffee. Youll probably find the grinder settings need to be slightly coarser for a freshly roasted bean than a store-bought (stale) one, but you should need no more than two or three shots to fine tune by then.
        I dont know why you would bother with cheap supermarket beans when you can buy fresh roasted quality (award winning even) beans for $24/kg.
        If it was saving a heap of money, fair enough,  but good beans dont have to cost the earth. Having said that, I prefer to roast my own.
        And yes the tamper is essential. Shot will change dramatically.
          Originally posted by 676066617C76150 link=1317310998/1#1 date=1317639741
          As for the espresso making part. I ground my supermarket bean (practice bean).... At the moment Im producing a bitter, bland and watery shot. I believe Im getting a 60 ml shot to pour in about 15-20 seconds. Way too short.
          Gday rustic.
          This is typical with stale coffee...
          Theyre probably putting 2 years on it. It was quite likely roasted in July 2010 and was stale by the end of August 2010.
          You really need to source some high quality fresh stuff if you hope to move forward from here. Good beans will make a massive difference (more than the difference between a cheap and a great tamper).
          Why not grab a popper and a CS sample pack and have a go yourself?
          Good luck
            Ah, I wish I lived in an area where that was the case! Jealous!
            But, yes, I agree. I roast my own and once you start roasting your own, there is no turning back!
              I have two of these so have had lots of practice and can now get very acceptable milk. Before you steam the milk, you need to give the steam a bit of a blast to get rid of any water in the wand. I use a 600ml jug and fill it to just below the start of the channel leading to the spout. I place the steam wand down against the closest edge of the jug with the tip just under the surface. The jug is held at an angle at this stage. As the milk steams and stretches, I straighten the jug slowly and lower it to keep the tip just under the surface. You will see the mik swirling in the early stages of the process. I can stretch the milk to around twice its original volume.
              This may not be text book style, but it works for me. I hope you can make it work for you too.
                Thanks for all the tips. Ill give them a go.
                  I ended up getting freshly roasted bean and a 52mm tamper.
                  The coffee is much better now but I still cant get 60mls to pour longer than 20 seconds. BTW, Im using the finest grind setting.
                  The store I got the tamper from did not stock a 53mm tamper and told me they are difficult to get. There is about 1-1.5mm clearance when placing the tamper inside the filter basket.
                  Is the size of my tamp a big issue?
                  If so, should I get another one or is it even possible to purchase a smaller basket?
                  I only have a double shot basket so I was thinking about purchasing a 2 x 52mm baskets (single and double shot).
                  Also, I am still having issues foaming the milk. Will practice a few more times before asking for advice.
                    You may find that because the is a small gap at the edges when you tamp the grinds down, you will get channeling down the sides. Channeling is where an uneven tamp causes the water to flow (channel) throughout the less firmly tamped section and as such the resulting coffee is less than perfect.
                    This may be why youre unable to pull slower shots.
                    Getting smaller baskets is not an option. They wont fit the portafilter.
                    As for the milk, there are some very good tutorial videos on YouTube, but it does take some practice.
                      If youre on the finest setting, you may want to look up the Breville "shim kit."
                      It shouldnt be too much of an issue, see the NSEW tamp which helps with the spacing down the edge of the basket.
                      The double shot basket is fine, I wouldnt bother with the single IMO, its much more difficult to get a great shot.
                        Originally posted by 353E262C3031333A30285F0 link=1317310998/10#10 date=1317907249
                        Can I combine a NSEW tamp with the following method?
                        http://coffeesnobs.com.au/YaBB.pl?num=1171315322/5#5
                        HalfFill
                        LightTamp
                        Fill
                        Tamp
                        Originally posted by 2F243C362A2B29202A32450 link=1317310998/10#10 date=1317907249
                        Can I put a single dose in a double basket?
                          I dont see why not, but that method is used to address another issue: updosing.
                          Try the 5c test to see how your dose is currently sitting.
                          No, unfortunately the double shot basket isnt designed in that way.
                          You can try and pull a double ristretto, yielding ~30-40ml from the double basket and see how you like that.
                            How did you go with the 52mm tamper? Does it work ok? The VV basket is 53mm i believe but they are very hard to find at a reasonable price.
                              The 52mm tamper seems to work OK. Although I still wish it was a tighter fit so that I dont have to apply the NSEW tamping technique. Its something I dont have to worry about.
                              The other thing I dont like about this tamper is that its a convex. A flat tamper would feel heaps better while compressing the puck NSEW.
                              I need a lot more practice to get a consistent dose and still need to try out the 5c test.
                              This is my technique, I would welcome any suggestions:
                              1. Fill basket with grinds till it reaches the top
                              2. Distribute grinds evenly with my finger in a sweeping motion
                              3. Tap portafilter on bench to allow the grinds to settle
                              3. Fill the basket to the top again
                              4. Distribute grinds evenly with my finger in a sweeping motion
                              5. Tap portafilter on bench to allow the grinds to settle
                              6. Using bathroom scales I tamp North at about 10 pounds
                              7. Tamp South at about 10 pounds
                              8. Tamp East at about 10 pounds
                              9. Tamp West at about 10 pounds
                              10. Tamp Centre at 30 pounds
                              11. Tamp Centre at 30 pounds again and polish without any pressure
                              12. Lock in portafilter
                              13. Turn on the brew button and pre infuse for 3 seconds
                              14. Turn off the brew button and wait 3 seconds
                              15. Turn on the brew button to pull shot
                              When done properly the puck has a pretty consistent texture throughout after pulling a shot. When done improperly the puck crumbles or falls apart when knocking it into the sink.
                              Im a bit worried that micro channeling could be occurring around the edges of the basket due to the convex shape of my tamper. How would I check this?
                              There are two other things I wont get into at the moment.
                              - Ive done a bit of searching for Milk texturing techniques for the Saeco VV but havent come across any detailed instructions.
                              - Temperature surfing techniques
