thanks for the advice. It makes sense that it's the collar because it's not the seal, and it was OK until quite recently. It doesn't look cracked so I assume the guides are worn, and I've ordered a new one from BigWarehouse. Will post update after I've replaced it.
Breville Cafe Roma water leaking over the edge and driving me crazy
installed a new collar this morning. Started pouring OK and suddenly, pop!, started spurting out past the seal again, just like before. I've replaced the seal (twice) and the collar, so there's obviously a third variable. With seals and collars I've thrown away about a third of the price of a new machine, so I'm going to cut my losses.
That's weird, I would've thought it'd work. I would think the only other possibilities is your group handle has worn or been damaged or the thermoblock itself has warped and as a result has weak points around the seal.Originally posted by dub View Postinstalled a new collar this morning. Started pouring OK and suddenly, pop!, started spurting out past the seal again, just like before. I've replaced the seal (twice) and the collar, so there's obviously a third variable. With seals and collars I've thrown away about a third of the price of a new machine, so I'm going to cut my losses.
But yes, either way both those options would be too expensive. You might be able to sell it for parts I guess.
It never required a lot of force to lock the filter in place, which I guess means it wasn't a particularly tight seal, and with time things wore down or warped and shifted just enough so it failed under pressure. Anyway, since I now own two brew head locks, I decided to play around with one. Around each of the 4 screw holes there is a 1cm diameter circle that is raised by about 1mm. I guess its role is to keep the collar body slightly apart from the brew head, and maybe there's a reason for that, but since the machine wasn't working properly, and I was on the verge of disposing of it, I thought I'd grind those lugs down. It now takes slightly more force to lock the filter and, touch wood, it's working without spurting water past the seal.
I had a similar issue in that it would "pop" the seal about half way though a pour, spraying grind and water all over the place. I was on the verge of throwing the machine away when I read this post and thought I had nothing to lose. I dismantled the base and ground away the spacing lugs in question. The portafilter lock now requires *significantly* more force than before. I've done quite a few shots with not a single pressure issue. So, I thank you. You have saved my Cafe Roma.Originally posted by dub View PostIt never required a lot of force to lock the filter in place, which I guess means it wasn't a particularly tight seal, and with time things wore down or warped and shifted just enough so it failed under pressure. Anyway, since I now own two brew head locks, I decided to play around with one. Around each of the 4 screw holes there is a 1cm diameter circle that is raised by about 1mm. I guess its role is to keep the collar body slightly apart from the brew head, and maybe there's a reason for that, but since the machine wasn't working properly, and I was on the verge of disposing of it, I thought I'd grind those lugs down. It now takes slightly more force to lock the filter and, touch wood, it's working without spurting water past the seal.
I have been looking for the group head seal (steam ring) for my Cafe Roma and note that Big Warehouse sell it for $17.35 (well over over 10% of the price for a new machine!) . It can be bought direct from Breville delivered for $15.00, and I can buy it locally for $12.00, but wait for it, the same part is available from USA for $1.67!! Of course the postage renders it uneconomical, but it just illustrates how blatantly we as Australians get ripped off. Shame on Big Warehouse!Originally posted by dub View Postthanks for the advice. It makes sense that it's the collar because it's not the seal, and it was OK until quite recently. It doesn't look cracked so I assume the guides are worn, and I've ordered a new one from BigWarehouse. Will post update after I've replaced it.
I have owned a Breville and Sunbeam, and I get my replacement seals from a guy on ebay: eBay link removed per site posting policyOriginally posted by avidonline View PostI have been looking for the group head seal (steam ring) for my Cafe Roma and note that Big Warehouse sell it for $17.35 (well over over 10% of the price for a new machine!) . It can be bought direct from Breville delivered for $15.00, and I can buy it locally for $12.00, but wait for it, the same part is available from USA for $1.67!! Of course the postage renders it uneconomical, but it just illustrates how blatantly we as Australians get ripped off. Shame on Big Warehouse!
While still more expensive than the US parts, they do the trick. But recently I've been having the same spurting issues with my Breville ESP8XL. I usually use a single wall basket, but the one I have doesn't have a little ridge around the top (like the Breville double walled ones that come with the machine) which I think could add to the problem of poor contact pressure with the seal. Also I'm thinking that once these replacement seals heat up with the head, they may soften up a bit which could add to the chance of water forcing it's way through. My issue usually comes with the second coffee I do (5 mins after the first, which works fine) so that could have something to do with it. I tried turning the machine off between shots, putting a towel soaked in cold water on the seal, half filling the basket, and I managed to get the second shot out with only a drip of water down the side of the basket holder which is better than the 'POP...SPRAY' that I've been getting! Now to figure out what action helped.
I'm thinking there could be some way to add some 'spacers' to the three arms on the filter holder, so to make them thicker and push up harder against the seal.
Replacement Parts
I realize this thread is old, but I came across it, and I had the same issue, after 6 years of flawless coffee. I was mortified at having to spend a couple of hundred dollars on a new machine when this one was so good. I found that ereplacementparts.com has a lot of parts for these machines, and they are very reasonably priced. $5.60 for this piece, and the seals were under $2. They shipped within a business day, (actually they sent me the tracking number on a Saturday), and the seal fit perfectly. I'm waiting for the "Carafe Fixing Seat" to get here so I can start making good coffee again.Originally posted by noidle22 View PostI recently repaired a cafe roma with similar symptoms. The guy i bought it from said he replaced the group seal with no luck. Being that there's only really two variables, or things that can perish/wear when the group handle is locked in it has to be one of them.
One is the group seal, the other is the locking collar. Below is a photo of the damage that the machine i had sustained:
