Originally posted by 7A46475C5A4B4B401F1D2E0 link=1334070170/3#3 date=1334104162
So does it seem like when you switch across to flow the water, nothing happens ?
It switches over, but no pressure.
Originally posted by 7C4F404A577169002E0 link=1334070170/4#4 date=1334113449
Next step is to decide if the pump is getting current (bad switch possibly), or if the pump is actually bad.. That will take some electrical knowledge and a test meter.
Looks like its going to be more trouble than what its worth then.
Originally posted by 546768627F594128060 link=1334070170/1#1 date=1334075391
When you turn the switch on to brew, does the pump sound normal? Does it run at all.
If you are looking for a more accurate diagnoses online you need to supply more info.
A refurb in the States is about $175. For a thermoblock machine with crema enhancing portafilter, that is not much less than what it would be worth new. Depending on the problem, if it only lasted 1 to 1½ years, why would you want another one of the same model? Might it be time to step up?
There is no sound or maybe a very tiny hardly noticeable bit if you put your ear up close. No flow at all.
