To much pressure...
  • #16
    I have seen in the Forum that you can use a Popcorn Popper as a roaster? Will this kill the popper faster that using it for Popcorn. (My kids may not like me killing it)
    • #17
      I was going to mention in my previous message, have you thought of roasting your own? Its fun, i wont say its hard but i wont say its east either. There are many ways you can roast at home and the popcorn maker is a place that most first start with.
      To answer your question about killing the popcorn maker it depends if the kinds like coffee popcorn. Alternatively, you can now buy cheap popcorn makers for as little as $20 at target and K mart. If you do some research on this topic of home roasting you might find that its a great thing to try very addictive.
      The good thing is there are heaps of people on here who can give you advice about it, its endless.....
      But yes the kids may not be happy with a over used popcorn maker that smells like coffee.
      • #18
        FWIW Phil, I would suggest you get your Gaggia performing as it should with commercially roasted beans you enjoy before you attempt roasting your own, too many variables all at once make it difficult to pin problems down.
        Once you know what your aiming for it may well be time to start roasting.
        • #19
          Re: To much pressure...
          Yeah ok, I will try the freshly roasted beans fron fastlane and get the macine running right first.
          • #20
            hi Phil
            Read all the above and believe your problem is the grinder if you could try a better grinder i am sure you will see a difference. Sunbeam 0480 at a minimum a friend had the same grinder as you have mentioned and same problem running too fast tried a better grinder and it was a lot better.
            • #21
              I have bought Beans from "The Fast Lane" and they roast every Wednesday and they let them rest for 2 days. I Grind some on the finest setting and it makes for a great Espresso, No more gushing it is nice and slow now and a great crema. The coffee is just amazing. I will never go back to supermarket beans again.
              Thanks for all your help guys, I really appreciate it.
              • #22
                Great stuff Phil, pleased to hear you got you result you were looking for.
                • #23
                  I am a sucker for a happy ending.
                  • #24
                    Phil, I was going to say: These Gaggia Classic machines work well with over-dosing – so overfill the scoop until it is nicely rounded, but not spilling. When you place the handle into the group head you should feel it tighten as it comes to the perpendicular position, or just before.
                    If doing this makes your dosage choke, then just lessen the does a bit.
                    Good that you are getting a nice crema out of it, thought. Sounds promising. I struggle with mine actually – and pretty much hate the Gaggia Classic for that reason. Will be posting a separate thread on that shortly.
                    • #25
                      See, this is SUCH a good site... I was considering going and buying some nice fresh coffee from a local roaster but also getting a pack of cheap beans from the supermarket so I could get used to my grinder - my Sunbeam EM6910 and EM0480 are less than a day old (to me - got them 2nd hand)
                      Now, thanks to the smarts on CS, I know that would have been a pretty much pointless waste of money - I'll just buy an extra kind of bean to try from the roasters.
                      Thanks guys...
                      • #26
                        Yeah I just read the how to make the perfect espresso thread, I followed the guide to fill the basket 3/4 full then tap the basket on the bench then keep filling to rounded and Tamp down.
                        It was tight when locking the portafilla on the machine. It made a good espresso and took the 30 sec for 30ML, It had nice crema.
                        I also did a mod on my Grinder to get a finer grind which worked out nice too.
