Hey folks, been quite some time since I have posted on here but getting back into the swing of things again. Having a fair few issues with my Gaggia which after reading countless valuable responses from here seem to not help my problem. The problem I am having is it seems no matter what coffee I am using (currently Proud Mary - Please Say Please Houseblend, roasted on the 11th of June), I am consistently getting a bitter, burnt cup. I mainly drink lattes as the shots are almost undrinkable (bitter, burnt). The Gaggia has a PID, the OPV mod, and is set to 92. I am using a single basket, with the same dose. The grinder is a EM0480, which seems to be fairly consistent in its grind, however I believe may be the underlying problem. As for how I make the coffee, I allow the machine to warm up, PF included, grind to a heap forms and level it off, tamp and insert the PF. Shots seem to blond within about 10 seconds if that, becomes watery and runs fast. So I set the grinder to one or two clicks finer, tamp the same and this then makes the machine choke and instead of espresso I end up getting more or less pure oil drips. Seems no matter what I do (reduce/increase boiler temp, change grind settings etc) all I get is either no coffee or burnt coffee. I am far from ready to get rid of the machine and I am willing to spend some time getting it right. So to all the Gaggia/EM0480 owners out there, what am I doing wrong?!
Gaggia Classic with PID and EM0480 - Bitter Coffee and Early Blonding?
Have you always used a single basket ?. The same basket ?.
If so, have you previously had good shots from the same setup ?.
I no longer use an EM0480 to grind for my Classic, and I hardly ever use a single basket. The few times I tried this combination, I found it very difficult to get the grind right.
The steps on the 480 were too wide and the single basket was too fussy. The grind, dose, and tamp all had to be just right, and even then the shot would often start to blonde at about 20 seconds or so.
If I need a small/weak coffee (usually for a visitor) , I use a double basket and stop the shot early.
The Pid is just a sestos cheapy with a washer type thermocouple, if I was to measure the temp of the water from the portafilter and adjust accordingly that would be a reasonable idea?, obviously the temperature drop would be the hard thing to work out. I have had mixed successes with the single basket and I'm assuming using that in the first place could be where I am going wrong. The beans themselves I haven't tried before but it's not just unique to these beans, no matter what coffee I put in the thing it always tastes burnt and bitter. Thanks for the responses so far folks
I'd sort out a way to measure discharge temperature (a bead thermocouple with a resilient sheath that you can stick on top of a spent puck is great).
If you really want to get into it, you might have a look at this.
Hey folks, bit of an update, ended up trying the double basket and wow do they make a difference! Definitely a whole lot better coffee. Il see if I can get some temps today from the group head. What temperature would you all recommend? I've heard 92 is the butter zone but figured I'd get others opinions being how easy it is to set it with the PID. Thanks heaps folks
I use 103 degrees Celsius on my Auber PID. They suggest 102. I use a triple basket that I dose with 22.6 grams of ground coffee to yield 42 grams of espresso in about 28 to 30 seconds from start of pump. I am guessing that your shots are over extracted due to channeling and brew temp too cold. Try weighing both the ground coffee and the espresso to not exceed 50% extraction. I use a Eureka Mignon Manual grinder. A bottomless portafilter will also help in pinpointing problems in the process.
The thing I am wondering about the temps is, the thermocouple for the PID is attached to the outside of the boiler (washer type, where the old thermostat was) and as I have set at only 92 I am wondering if by the time it gets to the group head its probably lost 10 degree or so. Will set the PID SV to 103 and see how that goes just for interest sake.
Apologies Jojo, I misinterpreted what Colen had meant.
Yes, there will be a temperature difference between the boiler external surface and the group water.
It's likely that the boiler surface will be slightly cooler than the boiler water (and the thermocouple could be slightly cooler again, depending on how it's connected). Insulating the outside should result in a measurement closer to the water temp (note, this would actually increase the difference between the measured temp and the group temp, but should result in a more reliable measurement).
In any case, measuring the group water temperature and the allowing an offset in the setpoint to account for the difference should give you a reasonable ball park. From there I would adjust to taste (if you can notice a difference).
Note: You might find the required offset will vary depending on ambient temp, airflow and how long the machine has been on.
Originally posted by Colen001 View PostThe thing I am wondering about the temps is, the thermocouple for the PID is attached to the outside of the boiler (washer type, where the old thermostat was) and as I have set at only 92 I am wondering if by the time it gets to the group head its probably lost 10 degree or so. Will set the PID SV to 103 and see how that goes just for interest sake.
The temperature will also drop substantially over the course of a shot.
It's also worth noting that because of the boiler-mounted element/TC, you will need to let the machine rest for a substantialy period 5-15mins?) between shots, as once the heating element kicks in you'll have a massive temperature differential between the boiler housing and the water.
Idle time will definitely impact the offset. Based on Auber's testing, recovery time is about 4 minutes after pulling a shot or flushing. There are many tricks that you can do with the Gaggia Classic and they can all be found in the Gaggia Users Forum. Some members have built a thermofilter to try to measure the brew temp as accurately as possible. I have not gone that far. I just adjust PID SV based on taste and my roast profile for a particular coffee.
